View Single Post
Old 01-13-2021, 01:36 PM   #10
redwire
City & State: Alberta
My Country: Canada
Default Re: 4017 counter reset problem
In your first circuit, I would make some changes, such as adding a driver transistor for the relay because a 4017 has weak output drive a few mA. It would be a circuit that either counts to one or two. It depends if the alarm has a signal with a level for when "on", so you could add a gate to make the counter go to one or two depending if the alarm is set on or off.
redwire is offline   Reply With Quote
