Unconfigured Static HTML Module
Static HTML Module Content
Need software for Intelligent universal programmer lk48
    I bought an universal programmer but I cannot find the software.It comes out in different names (Dataman 48uxp ,Labtool 48uxp etc).Maybe someone can help me find it .
    The device looks like this
    Thanks in advance,
    Re: Need software for Intelligent universal programmer lk48
    it's made by advantech
    http://www.aec.com.tw/
    [free]
    http://www.aec.com.tw/software_files/LT48UXP_83203.exe
    [needs a license / hack]
    http://www.aec.com.tw/10.htm
      Originally posted by stj View Post
      Thank you! Ill test it when I get back home on Saturday! Thanks again!
        I also own one of those, unfortunately
        Got it in exchange for something else back in 200x.
        Not only are the adapters very expensive as the software really sucks.
        On top of that you have to own a valid s/w license and keep spending money on every master release.
        To get an inside peak:
        48UXP (hw)
        Btw, if you find a full working software version please share.
          do you have the XP or the UXP ??
          btw, you can use universal adapters from ebay.
            The UXP version. Yes i'm aware. Thanks.
            Still the free software version makes it a piece of junk, useless really
              is it really missing that many devices?
              can you use the UXP model with the parallel port using the XP software?
                Yes! It might not be in quantity but any device that became ordinary is not supported, e.g. NAND flash.
                And for older common devices you really don't need it.
                Yes u can. I've tested it myself under XP (not sure with older version though).
                Releases for OS Vista / newer don't work with the parallel port, only USB port.
                  newer versions DO work with the parallel port if you have the driver for the port.
                  if you can get the 48XP soft to recognise the programmer, i can help with the license.
                  i'm attaching a seperate driver.
                  btw, the hardware cant support NAND no matter what software version you have.
                  what eprom version is in yours? i have 3.10
                    btw, when i say XP, i dont mean the operating system - i mean 48XP software
                      Yes it recognizes the programmer but stays in demo mode due to license.
                      Can you please help me 'fixing' this issue?
                      Firmware Version: 3.10
                      It really stinks not supporting NAND flash.
                      Do you know any cheap solution? Really need support for those.
                      I'm desperate to get my hands on a 512Mbit (NAND512W3A2SN6).
                        pm'd
                          pm'd
                          Thanks stj
                          Magic really happens
                            XP dosent automaticlly install the drivers. Can some help with them?
                            XP 32 bit.
                              what drivers?
                                what drivers?
                                XP dosent recognize the hardware when I connect the programmer.
                                  usb?
                                    usb?
                                    Ya. Also tried it on different slots. Still dosent recognize the programmer.
                                      with the programmer on, and a tested usb cable, does windows find *anything* ??
                                      if yes - what is the VID & PID
                                      and did you test it with the parallel cable?
                                        When I connect the programmer, I go through "Find New hardware Wizard"- I pick Install the software automatically" then I get an error : Cannot install this Hardware.
                                        I haven't tested it in parallel port cuz I dont have a cable.
                                        USB\Vid_0574&Pid_ea80&Rev_0001
                                        Thank you!
