INTEL D865GBF - D865PERC E210882 - PENTIUM 4 - mPGA478
    Great forum
    I have this Motherboard from Intel:
    E210882
    PENTIUM 4 - mPGA478 SOCKET
    At the moment no PCI boards, no USB or other peripherals.
    Only PS2 mouse, keyboard and VGA.
    Most of the time ... fans runs ... all lights ( front panel ) and no VGA signal. No beeps.
    If boots and we do restart ... front panel or in W$n ... no boot anymore.
    The caps tested with an ESR (EVB) in circuit.
    If any value members can confirm or disagree please write.
    1x 2200uF 10V 0,02
    4x 1200uF 16V 0,00
    3x 820uF 6,3V 0,00
    7x 680uF 25V 0,00 Japanese
    470 uF 10V 0,01 (near CPU ) 0,07 0,05 0,15
    0,17 the worst case 0,44
    100uF 25V 0,05 0,07 0,40 0,22 0,20 0,50 0,60 0,70 0,97 1,0
    47 uF 10V 0,02
    22uF 25V 0,03(C4G1) 0,22 0,10 0,44 0,06 (near AGP) 0,67
    22uF 16V 3,2 3,2 3,2 and one 0,29
    I need this board because we have 2 PCI boards for research (college) and can't continue, the W$n drivers are for this Board.
    Regards,
    RB
    Re: INTEL D865GBF - D865PERC E210882 - PENTIUM 4 - mPGA478
    Don't measure them in circuit, as you will get the 'combined' readings of all of the caps in that circuit and it doesn't tell you if any of the caps are bad. What brands of caps are on the board? Any Nichicon HM or HN, or KZG?
      Dear Sir,
      Thank for your comments.
      I know that if some paral. or serie cap. is in the way ... bad reading.
      But the bad values (very high ohm) we can detect.
      The low we can't see in circuit.
      And if some members have this board we can see the difference.
      Best regards,
      RB
        Intel boards have a jumper block, where an alternate setting is the equivalent of clearing CMOS
        Or no jumper fitted at all, is for doing an emergency reflash
        Download the manual for that board and check out what it says
        If it won't start with a different jumper setting, or no jumper at all, I'd say you're wasting your time persisting with it
        In my experience, when Intel boards die, they stay dead
        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
          as pfrcom says "In my experience, when Intel boards die, they stay dead" and in my experience boards built for p3 and p4 prossesors are the worst.
          Follow the white rabbit.
            Of course I did that.
            Please read my first post.
            I work with MacOSX, Linux and other computers.
            I tested the CPU and RAM in other Motherboards.
              I have several, P4 and don't see ...
              What Linux ... Distro????
              Regards,
              RB
                Rubycon and SMG
                The Japaneses please give some guidance ...
                Regards,
                RB
