View Single Post
Old 09-14-2018, 01:25 PM   #8
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Default Re: Modifying laptop adapter for 12v
Quote:
Originally Posted by Dannyx View Post
By "lower resistor" you're referring to the one going to GND ?
Correct.
I was concerned that lowering the resistance between that pin and GND will cause more current draw, so I thought I'd lower the VCC one instead
You misread my above post.
If changing resistor between pin 2 and ground, _increase_ the resistance. (This will cause a higher voltage readout at pin 2, and hence more often pulling of the output to ground).
If changing resistor between pin 2 and Vcc, _decrease_ the resistance. (This will cause a higher voltage readout at pin 2, and hence more often pulling of the output to ground).
CORRECTION: with the inverting input tied directly to GND...
Well, if you are trying to have any kind of regulation, you never tie any of the op-amp pins to ground.
And if you tie pin 2 to Vcc, your PSU will output the reference voltage set by the resistors on the lower-right side of your diagram (the ones that connect Vcc, pin 5, and ground).
