ps4 power supply resistance out of order, what to choose?
    Hello
    After checking this resistor which gives no value on the ohmmeter on a PS4 SLIM power supply.
    I would like to change it but by which power I can choose it knowing that this resistor is on the primary part that is to say on the 230/400 V side
    Value 16.8 Ohm normally according to color code (See photo)
    1st ring = Brown = 1
    2nd ring Blue = 6
    3rd ring Grey = 8
    4th ring OR Multiplier = x0.1 Ohm
    5th ring Red = +/- 2 %.
    Tolerance of either + or - 0.336 ohms
    Dimension of the resistor Length = 6.4mm, Width 4.8mm
    Can I place one between 15 and 17 Ohm or a little more?
    What power in Watt I can order if it is 2W or 3W
    I don't want to do anything stupid about the value to choose
    Thanks a lot to you
    Re: ps4 power supply resistance out of order, what to choose?
    This is a safety resistor, plays the role of a fuse (0.16 Om. 5%).
      Strange because it doesn't even sound continuous in this case
        What is strange here, 3 stripes (silver) is a multiplier of x0.01.
          I was really surprised to see this silver stripe in the 3rd position, so I considered it as a grey color.
          I can't find any other information about a silver band in the 3rd place for 5 rings.Maybe it should not be taken into account then =S so I will have to calculate it as 4 rings.
          This would give 0.16 Ohm but tested in several modes Diode or megaohm the resistance gives nothing at all.
          Only I need an example of a resistor on the same power supply of a ps4 slim
            Is this the resistor at location F3? if it is, it is a 0.16Ω-2watt. Lotas post #2 is correct
              So the resistor is indeed 0.16 OHM which acts as a fuse we will say.
              I ordered a 2W and it is much smaller, so I took a 3W which is the same size and the power supply works now
              Many thanks to you
                I don't think I've ever seen a multiplier band of gray (and definitely not white), it's always been silver of that set of similar colors.
                Purple multiplier is rare enough as it is... I think I've only seen 1 or 2 ever.
