Quote:
Originally Posted by budm
If you suspect that E-B junction is shorted then you should be able to use Ohm meter to check the resistance between E and B pin if the suspect transistor.
OK, I will do that and post the resistance. Should I discharge the caps before I take a measurement of the transistor's resistance?
Thanks!
