View Single Post
Old 05-29-2018, 12:33 PM   #17
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Re: Repair Fence Energizer SS-1000E Fi-Shock
I was guessing C2 as bad as if it were leaky it could also never trigger...but that would somewhat be a wild guess.
It is worth to test if the SCR is still good. If you have a 12V PSU, a small 12V light bulb (NOT SMPS LED), and a 1K resistor you could do a simple test:
Connect PSU+ -> anode of SCR
cathode of SCR -> Light bulb contact 1
Light bulb contact 2 -> PSU-
Light bulb should remain OFF.
Then touch the gate of the SCR through the 1K resistor to PSU+ momentarily.
Light bulb should turn on and stay on.
If this is the case, the SCR is probably good.
eccerr0r is online now   Reply With Quote
