View Single Post
Old 10-15-2017, 10:15 PM   #25
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: Philips FR-740 working but no audio output
On page 78, MFD looks like it should be 0 volts on base of 7253 (power down circuit) and the collector should be +5 volts (amp pd)
A lot of the voltages are marked so make sure they are all ok, the only one I can see that is not right is that {amp lr} line, it should be +5 and its 0 so the main amp ic's are not turned on.
That amp lr line is controlled by one of the output lines of ic7412 (page 34) and that ic takes data in to control the output lines, so something (microprocessor) must not be telling it to turn on pin 6,
R_J is online now   Reply With Quote
