The extrasensory perception solder iron. First 12v double solder irons in the world.
    First 12v double solder irons in the world for Auto, with an incandescent lamp, Non-polar, true extrasensory perception solder irons.
    3) A big iron tip for large connectors and smaller iron tip for fine jobs.
    Re: The extrasensory perception solder iron. First 12v double solder irons in the wor
    How are you Controlling the temperature on this iron
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      it is a very good question.
      Temperature controlled by your extrasensory perception, by your consciousness, by your mind and your fingertip with An on/off switch.
      1) put two 24v T12 together become 12v
        Are you talking about the [ ( cartoon) Flint Stone ] method
        If so
        This is funny
        9 PC LCD Monitor
        1 Dell Mother Board
