View Single Post
Old 12-30-2010, 10:14 PM   #12
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
My Country: USA
Line Voltage: 120V 60Hz
I'm a: Professional Tech
Default Re: KZG - KZJ - Same Electrolyte
In Aluminum Electrolytics the Aluminum Oxide layer -IS- the Dielectric.
The separator paper is only in there to act as a carrier [flow path sort'a] so the electrolyte can get to the Aluminum to keep it oxidized.
Ripple currents blast chunks [figuratively] of the Oxide [or Aluminum depending on instantaneous polarity] into solution where it disolves.
The DC voltage present restores the damaged areas similar to how electroplating works.
- That's why electrolytics used to be called 'self healing capacitors', although the term has fallen out of use over the years.
__________________
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
