Dell latitude 7490 Bios password
    Re: Dell latitude 7490 Bios password
    Originally posted by imranromi View Post
    You need bios programmer any read your bios chip.Search Google you find many if any you suit buy just simple..
    I will have a buspirate this week and can pull the dump, but I don't know what chip to use. Also have 8fc8
      Wait for my tomorrow i will check this code i work this suffix will soon finish maybe i will send you tommorrow.Send pics lock or serial number this suffix
        Does this work?
          OK. So this is not only a software I have to run on my computer to access the chip. I need some hardware as well. This was the bit of information I was missing. Thanks!
            That would be very helpful. I would be glad to test this for you. See my unlock code attached. I am not sure whether it is the letter O or the number 0 in the middle of the code, though.
            Thanks!
              Did you get anywhere with codes for 8fc8?
                Any luck? Thanks!
                  HI
                  I need code too if u can help, service tag 5QYGLQ2-BF97
                  thanks in advance
                    Originally posted by pei View Post
                    HI
                    thanks in advance
                    Your Tag password.
                    1mbUR8bkW2EjRMb3
                      Thanks!
                      @imranromi, I am still monitoring this thread just in case. Still would be appreciated.
                      Cheers!
                        Cheers!
                        I already work this algorithm But still no luck I also need code this lock soon for testing.Use bios programmer any and send me bios
                          Thanks, I will look into it.
                            any update for dell suffix 8fc8?
                              still can't unlock suffix 8fc8?
                                Which model show this Tag?
                                  Dell Latitude 5501
                                  Service Tag: 699R3Z2-8FC8
                                    Dell Latitude 5501
                                    You have bios dump post here.
                                      I'm sorry, i don't understand what that mean.
                                      Do i have to install that? how?
                                      Do i need extra hardware to do that?
                                      Thanks!
                                        Hi guys are you able to unlock this 2PDJWT2-E7A8
                                          Plus I need code for Dell no sufix
                                          9FHCRT1
