Here is a new test instrument which i received today. It is an ESR Meter based on Australian Bob Parker's famous design
It is built by EVB of Portugal. The pic above shows what you get, namely the meter, two substantial test leads (i was quite impressed they are much thicker and larger than those you usually get with a cheap multimeter. Also you get a 100 ohm 5w power resistor which you use to discharge filter capacitors in power supplies to avoid damaging the meter when you test them. You also get an owners manual which is quite comprehensive and in good English. Lastly you get a 2 year guarantee certificate.
