Badcaps Forums
Badcaps Forums (https://www.badcaps.net/forum/index.php)
-   Troubleshooting TVs and Video Sources (https://www.badcaps.net/forum/forumdisplay.php?f=31)
-   -   Plasma new on on me (https://www.badcaps.net/forum/showthread.php?t=21442)
Captin21 07-08-2012 02:54 PM
Plasma new on on me
I have a Panasonic 42 Plasma pt # TH 42pz80U any how when i got it it looked good but it appeared to be that someone or somehow the aspect had been shrunk up to where on each side there is a 4 inch dark section the top and bottom are fine just the sides i cannot adjust that back and it affects the menu and anything else it is not the buffer boards i can remove the straps and it is different size and different looking in general I then thought it was the A board and looked it over couldn't see nor find any issue so i sent it in for repair thinking it must be it . It came back with a note nothing wrong with this board ??? Now what could it be the little control board that attaches to the buffers but like I said if i remove the affected leash area it looks very different . any ideas i could attach a picture but it looks normal aside from the two sides are blacked out about 4 to 5 inches ,
tom66 07-08-2012 03:44 PM
Re: Plasma new on on me
Can you show us a picture? Have you tried the ASPECT ratio button?
cadiman 07-09-2012 05:18 PM
Sounds like it had the wrong board installed (smaller model) or you still have an issue with settings.
You should be able to really stretch the picture out on a plasma pending aspect settings.
Also make sure your input is not the problem.
The panasonics have a lot of setting adjustments and having the correct remote is a must with a plasma tv.
Is the pz80u a commercial moniter?
