Badcaps Forums
Badcaps Forums (https://www.badcaps.net/forum/index.php)
-   Troubleshooting Laptops, Portable, and Mobile Devices (https://www.badcaps.net/forum/forumdisplay.php?f=23)
-   -   Acer 4530 - powers on then shuts off 2 seconds later (https://www.badcaps.net/forum/showthread.php?t=17148)
12ax7a 10-28-2011 01:43 AM
Acer aspire 4530 - powers on then shuts off 2 seconds later.
This seems to be a fairly common problem among many manufacturer's laptops described on the web.
Anyone know the cause / fix?
nish_pinto 10-28-2011 08:50 PM
Re: Acer 4530 - powers on then shuts off 2 seconds later
Of what nature is the problem? Could you please elaborate?
chosentestament 10-29-2011 07:24 AM
Does it get to POST first? If it doesn't get to POST it sounds like it may be a power supply issue.
12ax7a 10-29-2011 09:29 PM
Nope - no post. no bios writing. tried three different external adapters - all good. no difference.
Nature of the problem: Press power button.. blue LEDS do their 'go around thing' for about 1.5 seconds ... fan makes brief blowing noise .. no bios writing on screen ... unit shuts off. charging of battery & charging LED seem to function correctly. changed CPU. changed memory. disconnected all device loads - that is: hard drive, CD rom, modem, wifi, etc. DC jack seems good. same problem regardless of whether screen is connected. reapplied silver thermal paste on cpu. graphics chip heat transfer pad seems fine. same behavior regardless of battery connected or not. no obvious shorts in USB connectors or otherwise. 5V & 3.3V stand-by appear to be there. ...
12ax7a 10-29-2011 10:51 PM
the consensus out there seems to be Nvidia video chip requiring reflow or reball.
everybody agree?
trebo 10-30-2011 03:12 AM
everybody agree?
mine was acer travelmate 5320, similar symptoms, lots of lappys out there with similar symptoms, and no fixes or help
your lappy like mine is NOT known to require reflow, like some lappys DO
mine turned out to be CPU
I was about to replace the bios chip before cpu
reflow seems drastic at this stage (they dont seem to last anyway)
hotkey 11-01-2011 12:05 AM
My problem just same
my laptop acer 4740 die after a few minit in win
this pronlem like chipset over heat or fan run badly
i still can't solve this problem
all voltage in motherboard is good.
specific 11-01-2011 11:06 AM
hi
for acer 4530 prob is around the nvidia chip
reflow or reball is recommended
its actually coprocessor not only vga
u can just heat the chip for some time and check
regards
12ax7a 11-05-2011 06:25 PM
tried it once but i'll try it again. thanx.
starmaxpc 11-13-2011 11:05 AM
everybody agree?
YES!! i had one of these laptop's. stripped in down re heated the nvidia with hot air gun and also shimmed it with a dime, yes a dime, temporary fix. still working to this day no problems. did it 2 months ago. There..... put in my "10 cents" worth! Har Har...:nod:
swanand 12-13-2011 05:34 AM
first check with the another cpu... if problem is steel there then you will need to replace nvidia mcp77 bga chip
Regards
swanand
charlee_77 05-22-2013 09:36 AM
:usa:
Nature of the problem: Press power button.. blue LEDS do their 'go around thing' for about 1.5 seconds ... fan makes brief blowing noise .. no bios writing on screen ... unit shuts off. charging of battery & charging LED seem to function correctly. changed CPU. changed memory. disconnected all device loads - that is: hard drive, CD rom, modem, wifi, etc. DC jack seems good. same problem regardless of whether screen is connected. reapplied silver thermal paste on cpu. graphics chip heat transfer pad seems fine. same behavior regardless of battery connected or not. no obvious shorts in USB connectors or otherwise. 5V & 3.3V stand-by appear to be there. .......
