win7 bs
    • 31015
    win7 bs
    trying to install dotnet4.8
    it's not having it,
    the log says something about not finding a hashfile for "setup utility.exe"
    fucking shit o.s. is of course not saying anything usefull other than in the install-log
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: win7 bs
    Usually it it because of both missing certificates and possibly the SHA2 compatibility updates for Windows Update, required since around 2020 some time.
    You can install the updates under "Prerequisite" here (except for the ESU Licensing Preparation Package) that should take care of it:
    https://support.microsoft.com/en-gb/...3-80b305a31686
      • 31015
      Re: win7 bs
      the SHA2 thing fixed it.
      the other shit wouldnt install anyway.
      all this trouble just to program Motorola radio's!!!
      shit software installer.
      • japlytic
        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
        by japlytic
        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
        Tried (only with keyboard/mouse connected):
        • BIOS + database update
        • Using latest Windows 11 image built with official image creation tool
        • Previous setup version for Windows 11 installer
        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
        06-19-2025, 04:59 PM
      • 24gsm
        MacBook Pro A1708 install macos fail
        by 24gsm
        hi to all
        i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
        after enter to recovery and format hdd 1to .
        after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
        can help please
        Serial Number: FVFXP0U0HV2J
        Config Code: HV2J
        Find My Mac: OFF
        04-16-2025, 03:57 AM
      • duwane
        A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
        by duwane
        Hi All.
        Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
        The issue:
        Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
        10-26-2022, 07:02 AM
      • eccerr0r
        win7 home iso? can I get 10?
        by eccerr0r
        Well I think that I have a GTX660Ti that's dead but I think I should give it one last try with its original OS and drivers: win7 home premium. While I can't stomach using win* of any type (I'm 100% Linux these days) I think I have to give benefit of the doubt to drivers, etc.
        So... I have the original CoA for Win7 home premium and it's an OEM license. And I have the whole computer that the GTX660Ti came in (it was reportedly working too), minus the original hard drive, what could I download and run the machine temporarily to verify the GTX660Ti works with Windows or not?
        09-14-2023, 07:35 AM
      • TrumanHW
        MacOS: R|W Programmers like CH341x BINs..?
        by TrumanHW
        For years I tried figuring out how to R|W BINs from my CH341x programmer.
        From FTDI's pkg, Apps specifically claiming they work, I failed for ~8 years.
        I'd expect many here figured it out (easily), but in case not ...
        It's one of the few forms of "how-to" remuneration I can GIVE BACK.
        This group is both GENEROUS & literally BRILLIANT / GENIUS!!!
        This may be the easiest means to copy-paste:
        Code:
        SERIAL -to- USB - CH341 ROM (MacOS):
        Install xcode:				xcode-select --install
        Relocate
        04-08-2022, 02:33 PM
