HDD test apps.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: HDD test apps.
    Originally posted by dood
    Tried to reply to this once before, but the forum timed out.
    I like HDTune in Windows, because it allows me to eliminate the controller on the motherboard as the issue. I hook the drive up to my PC, boot up, and run all of my diagnostics in Windows so that I can also be doing other things at the same time. Saves me having to have a PC just for testing hard drives. I do also use SeaTools on occasion.
    As for Ghost, they still have a DOS version, you just have to have the Corporate product, not the home product. I use it at work almost daily.
    Makes sense as the OS is not on the drive under test.
    Mann-Made Global Warming.
    - Dr Seuss
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Re: HDD test apps.
      I like HDAT2
      It is a DOS based utility for doing lots of things with harddrives, can view SMART data and also the SMART log that drives keeps, have never found any other utility that can display as many stats about a harddrive as this can...
      http://www.hdat2.com/
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Re: HDD test apps.
        I like HDAT2
        Thanks for the link. Hadn't heard of that one... will have to give it a go.
        Ludicrous gibs!
        • blowing_in_the_watts
          • Jul 2010
          • 21
          Re: HDD test apps.
          best and easiest to get:
          hirens boot cd 9.9 or up
          it has everything and usually always works
          oops.. did i just leak some important tricks for the pc repair guy that didnt know how to install windows XP OEM home using a XP pro corp key?
          well there you go
          and yea, i got plenty more
          but believe me everyone...
          hiren's boot cd has basically been the cd i have everywhere
          but never LEAVE anywhere....
          because its dangerous for the noob
          • chth96
            How Can I test PWM DM0365R?
            by chth96
            Hello
            I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
            So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
            I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
            I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
            06-18-2025, 04:14 PM
          • khelane
            test active pfc power with lamp test
            by khelane
            Hello
            I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
            Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
            Is there a way...
            06-03-2025, 01:00 AM
          • irepair559
            Ps4 1215a hdmi diode readings good everything good but no pic??
            by irepair559
            PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
            01-05-2023, 12:32 AM
          • hemant_2222
            Yamaha 2064 No sound but Test audio working
            by hemant_2222
            Hello Guys,
            Greetings!
            Hope you all are doing well.
            I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
            PCM1681DBQR - IC263 and it worked fine.
            Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
            11-01-2025, 11:20 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
