HDD test apps.
  • stevo1210
    • Oct 2006
    • 4156
    HDD test apps.
    I'm looking for a program that I can use to test some HDDs to see if they're good or bad? like in terms of sectors etc.
    What are some good free ones?
    Thanks.
    • 30964
    Re: HDD test apps.
    the best are tailored to the drive hardware - what drives are they?
    WD and Seagate for example both have bootable cd images with test-programs on them.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      Re: HDD test apps.
      HDTune.
      • NxB
        • Feb 2009
        • 1595
        Re: HDD test apps.
        Hirens has diags for everything. i usually use the WD one.
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          Re: HDD test apps.
          Originally posted by Scenic
          HDTune.
          *cough*.... agreed.
          Ludicrous gibs!
          • stevo1210
            • Oct 2006
            • 4156
            Re: HDD test apps.
            this one's a WD scorpio...
            • c_hegge
              • Sep 2009
              • 5219
              Re: HDD test apps.
              I use Seatools. It's made by seagate but works with all drives
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Re: HDD test apps.
                Run Active KillDisk on them first. [Free version is good enough.]
                The firmware on Formatted drives will map around bad sectors and sometimes they [the remapped bad sectors] won't show up at all.
                Mann-Made Global Warming.
                - Dr Seuss
                  • 30964
                  Re: HDD test apps.
                  use the manufacturers tools, some of them also check the electronics as well a the surface of the disk.
                  in the case of WD some can even set & clear options on the drive relating to noise-vs-performance.
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    Re: HDD test apps.
                    ^ AAM ... HDTune does that too.. on the fly.. post #3 *hint hint*
                    • kaniki
                      • 514
                      Re: HDD test apps.
                      One thing to note about the seatools by seagate. it will test pretty much add drives, no matter the brand, but the temp sensor part i do not think works right. I once tried it on a brand new drive. just got it in and factory sealed. put it in, did a quick test using seatools, gave me an over heated error. It was not a seagate drive, but still, the drive was brand new.. there should be no way that it had been overheated as i was its first owner (besides the store that sold it that is). Just a fair warning, if you do get that error, then it may not be overheated even though it says it is..
                      • seanc
                        • Nov 2008
                        • 1319
                        Re: HDD test apps.
                        Seconded on the temp sensor part.
                        I was once testing a batch of drives with Seatools and a few of the thin Maxtors popped up with something bizarre like 160˚C, a guy in the room shouted DON'T TOUCH THEM!!! I then pointed out that the workbench should have been melting.... it was perfectly cool.
                        If you want a rough guesstimate of something while you're working remotely on a PC or don't want to reboot, Speedfan is a good one. It'll take the raw SMART data and convert it into an easy to read list with description of bad values.
                        If a drive is flagged as bad by Speedfan SMART analysis, it's *usually* correct.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Re: HDD test apps.
                          +1 for speedfan
                          ubuntu also gives a good readout of SMART data and drive temp via the stock disk utility. no install required, you can use it form the live cd if you wish. also good for r/w rates, etc.
                          sigpic
                          (Insert witty quote here)
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Re: HDD test apps.
                            I've had seatools incorrectly report the temperature as well, but I usually discount that when deciding whether to replace it or not. If there is nothing wrong with the drive, it will still pass seatools tests, even if it thinks it's too hot.
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              Re: HDD test apps.
                              So lets all ignore HDtune.
                              Seriously, it works with all drives, runs right from windows, tests the surface of the disk, reports smart data and a whole bunch of other stuff.
                              • toastygoodness
                                • Jul 2005
                                • 813
                                Re: HDD test apps.
                                yeah hdtune. that or data lifeguard tools. but hdtune is the best. systemrescuecd works too, got a lot of misc linux tools.
                                  • 30964
                                  Re: HDD test apps.
                                  it's possible that seatools is just translating because seagate drives contain bullshit smart data.
                                  i'v got reams of smart-logs on my pc about pending this, and head error that - total bullshit.
                                  i get the same from every damned seagate drive i test from several ranges.
                                  i suspect that seagate has "twisted" the smart data somehow so only there own tools can interpret it.
                                    • 30964
                                    Re: HDD test apps.
                                    you dont want something that needs an installed o.s.,
                                    you need something that will run from a bootable disk/usb device.
                                    it reminds me of the way norton ghost has gone,
                                    how can you restore a backup or test a drive if the o.s. cant boot and the app only runs in windoze!
                                    • NxB
                                      • Feb 2009
                                      • 1595
                                      Re: HDD test apps.
                                      Thats why I like wd DLG.
                                      I use acronis for imaging, also runs from dos.
                                      • dood
                                        Deputy dood
                                        • Mar 2004
                                        • 2462
                                        Re: HDD test apps.
                                        Tried to reply to this once before, but the forum timed out.
                                        I like HDTune in Windows, because it allows me to eliminate the controller on the motherboard as the issue. I hook the drive up to my PC, boot up, and run all of my diagnostics in Windows so that I can also be doing other things at the same time. Saves me having to have a PC just for testing hard drives. I do also use SeaTools on occasion.
                                        As for Ghost, they still have a DOS version, you just have to have the Corporate product, not the home product. I use it at work almost daily.
                                        Ludicrous gibs!
                                        • chth96
                                          How Can I test PWM DM0365R?
                                          by chth96
                                          Hello
                                          I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                          So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                          I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                          I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                          06-18-2025, 04:14 PM
                                        • khelane
                                          test active pfc power with lamp test
                                          by khelane
                                          Hello
                                          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                          Is there a way...
                                          06-03-2025, 01:00 AM
                                        • irepair559
                                          Ps4 1215a hdmi diode readings good everything good but no pic??
                                          by irepair559
                                          PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
                                          01-05-2023, 12:32 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • salim5566
                                          loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                          by salim5566
                                          Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                          06-26-2025, 03:25 PM
