Is this a 4 amp fuse? or even a fuse at all
  • eradz
    • May 2010
    • 20
    Hey all, need some help on fuses.
    I got a bad 3 amp fuse on an inverter board on another comp. I tore apart this old monitor and check the board. I think i found what could be a 4 amp fuse. In the pic the white thing has a 4 on the top. Im guessing its a 4 amp fuse? If it is, could i replace the 3 amp fuse with that 4 amp fuse?
    eradz
    http://img408.*************/i/isthis4ampfuse.jpg/
    Here is what the board looks like:
    http://www.lcdpart.com/Products/715l9171a5.html
  • pentium
    • Mar 2006
    • 2778
    Re: Is this a 4 amp fuse? or even a fuse at all
    White rectangular block with metal ends? Sounds like a fuse to me.
    go at it with a DMM and see if it's blown or not.
    Find Nedry!
    Check the Vending machines!!
    • eradz
      • May 2010
      • 20
      I checked connectivity with the fuse(what i think it is) in the pic and its working fine. I just need to make sure thats a fuse and its 4 amp. Im new to this whole circuit board thing.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
        After all of...
        07-13-2024, 08:14 PM
