Can a new computer smell like urine?
  • SluggerB
    • Aug 2020
    • 747
    • US
    So I assembled my new PC. Ir runs fine, no issues whatsoever.
    I noticed I was starting to get a strong odor of urine in my bedroom (the room the PC is in). The only new thing in the room is the PC.
    Just to eliminate all other suspects, I turned the PC off, unplugged it, and then spend all day today cleaning the room. Like really cleaning the room. The urine smells is gone now. Tomorrow I am going to turn the PC on and if the urine smells comes back, then thats the culprit. But why in the world would a computer make a urine smell?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Can a new computer smell like urine?
    Leaky caps have a smell of ammonia.
    • SluggerB
      • Aug 2020
      • 747
      • US
      It was a very strong, pungent urine smell.
      The motherboard says it has a "Solid Capacitor Design" https://www.asrock.com/mb/AMD/970M%20Pro3
      Here is the PSU in the computer
      https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      The video card and HDD's are a swap from another PC that didn't smell, so I don't think they are a possibility.
      • desert-rat
        • Mar 2014
        • 4103
        Do you have young kids or critters?
        • SluggerB
          • Aug 2020
          • 747
          • US
          no pets, young daughter swears she did not have an accident
          I still have the PC off and the smell has not returned. I will turn it on tommorow to confirm or deny if the PC is the source of the odor
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            Let everything finish outgassing. This can take a few days. If it persists, check the caps.
            FWIW, outgassing of plastics & glues curing is what creates the 'new car smell' in a new car.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • SluggerB
              • Aug 2020
              • 747
              • US
              I'm aware of VOC odors, but this was a STRONG urine odor, stronger than I have smelled VOC's before. I have been using the PC off and on for a few days.
              I am still not 100% sure it IS the PC, tommorow will determine that. If running th PC causes the odor to return, I'm guess it can only be wither the motherboard or PSU, and I would likely suspect the PSU both because the motherboard is advertised as having "solid caps" and the PSU has a fan in it that would blow the odor out causing it to spread as much as it did.
              We will see what tomm brings
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                Do you have any pets? Old carpet? Humid?
                Team : 49813
                Join in!!
                Team Stats
                • redwire
                  • Dec 2010
                  • 3912
                  I find new PC power supplies stink terrible - the varnish, fiberglass resins, plasticizers will off-gas for at least a week or two. So that is more like Dollar Store stink than urine. Unless the cat pissed on it.
                  • desert-rat
                    • Mar 2014
                    • 4103
                    You might try the PC in a different room.
                    • SluggerB
                      • Aug 2020
                      • 747
                      • US
                      Just to close the loop, I restarted the PC and the odor never came back so it must have been something else.
                      • SluggerB
                        • Aug 2020
                        • 747
                        • US
                        OK, the case is reopened. I took a side cover off the case, fired up the PC, and the odor does seem to be coming back. It is less "urine"-y now and def more of a "hot electronics" odor. I sniffed around the inside of the case and best I can tell it seems to be coming mostly from the CPU cooler itself. My temps are 21-22C so nothing is overheating, the cooler itself is cool to the touch. It'a an overall very low power system. The power supply does not seem to smell at all. I looked around with a little flashlight and see nothing leaking, burned, or otherwise out of the ordinary. I touched around various areas and the only mildly warm thing I felt is a passive heatsink on the motherboard which I assume is the Southbridge
                        I used a fresh application of Arctic Silver thermal paste when I installed the CPU cooler. The cooler itself is a "black" model, maybe it's that paint curing over time?
                          • 31294
                          maybe the fan plastics are the cause.
                          i got a radio a while back - the moulded plastic tray in the box smelt so bad that i binned it
                          • SluggerB
                            • Aug 2020
                            • 747
                            • US
                            If I sniff around the inside of the case the only whiff I get is from the CPU cooler. That does have a fan on it.
                            This is the cooler I have https://www.amazon.com/gp/product/B08HH6G48J/. It is painted/coated/made black somehow, my thinking is maybe whatever the black coating is needs to cure? The only really hot thing in the PC is the CPU, and by contact the bottom of the cooler. When I touch the upper fins of the cooler it is barely warm though. But the smell is building up. Not sure if it is worth swapping out the CPU cooler for a different model
                            • SluggerB
                              • Aug 2020
                              • 747
                              • US
                              Here is a pic of all my temps.
                              • SluggerB
                                • Aug 2020
                                • 747
                                • US
                                I took the PC apart, and the smell is definitely coming from the motherboard. It is coming from the area of the expansion slots. I took off the northbridge heatsink, and the heatsink itself does not smell, but the chip underneath does. I cleaned the entire area of the board with IPA, but the smell is not going away. The only things near this area of the board are the plastic PCI-e and other card slots, the BIOS battery, the northbridge, and some random caps. There is no leakage or damage on either side of the board in that area
                                  • 31294
                                  must be the plastic connectors then.
                                  maybe heat does it - try using a hair dryer
                                  • SluggerB
                                    • Aug 2020
                                    • 747
                                    • US
                                    I took a q-tip and some 99.9% IPA and started rubbing around the area. In some spots along the expansion card slots, the qtip took some sort of residue off that look black on the Q-tip. So there is something on there. I did smell the PSU, RAM, and CPU, CPU Cooler, and thermal paste when they were off the board and they all smelled fine, so it's definitely the board.
                                    Tonight I am going to do a full teardown of the machine, load up my little spray bottle with fresh 99.9% IPA, take a brand new ultra soft toothbrush, and really scrub down the entire motherboard. If it is some sort of reside or coating that was just not washed off at the factory, that should clean it up. I took a detailed visual examination of the area and nothing seems wrong, no caps bulging or leaking, and while in operaiton the board functioned flawlessly.
                                    As an aside someone said in another forum that Mass Air Flow Sensor cleaner also makes a good circuit board cleaner? By happenstance I just bought a fresh can of MAF cleaner yesterday, I could give the board a good spraydown with that before going in with the toothbrush. Or is straight IPA preferred?
                                    • kaboom
                                      "Oh, Grouchy!"
                                      • Jan 2011
                                      • 2507
                                      Actually, I use MAF sensor cleaner on PCBs, if/when I don't want to "waste" my CRC QD.
                                      Are we certain this is a *new* motherboard?
                                      Not that I do it much anymore since the bottom's fallen out around here, but:
                                      My usual routine is IPA+ Simple Green, "spray & wait" (5-20mins), then thorough rinse w/ either cool tap water or RO filtered water if something like optical pickups or inkjet printheads.
                                      If it involves cigarette-paste-infused TV/VCR/DVD/stereo boards, I've been known to use 409, various "orange cleaners," and even Spray-Nine.
                                      For a mobo, I first use an electric "air duster" such as used in the 80's-90's for TV & other electronic servicing, to remove most of the water from the PCI & RAM slots.
                                      I have an apparatus consisting of an inline blower and 1980's PTC Pelonis heater.
                                      I turn the heater way down and have the blower's intake an inch or so away from the heater's front; most of the air bypasses the heater and the result is 80-100 degree air at the blower discharge.
                                      I attach a round cardboard "duct" to the blower outlet and place the PCBs inside to dry.
                                      With something like a mobo, I "blast" it in quadrants, rotating it every half hour, for maybe 4 hours.
                                      When I *think* it's dry, it gets another hour to be sure.
                                      "pokemon go... to hell!"
                                      EOL it...
                                      All style and no substance.
                                      guilty,guilty,guilty,guilty!
                                      guilty of being cheap-made!
                                      • SluggerB
                                        • Aug 2020
                                        • 747
                                        • US
                                        I assume so, it came in original packaging and all the anti static bags looked new and properly sealed.
                                        I think I will just use IPA, I have 2 big jugs of it and I use it to clean electronics all the time so I know it' safe. I will be scrubbing it clean, then leaving it overnight to see if the odor returns, so it will have plenty of time to dry
                                        • rumi409
                                          LG OLED C1 Pixel Cleaning Made Picture Worse
                                          by rumi409
                                          ​​​​​​ Hi,
                                          I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
                                          11-15-2024, 01:09 AM
                                        • howardc64
                                          Macbook Dust-Gate Preventive Cleaning
                                          by howardc64
                                          Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
                                          Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
                                          https://www.ifixit.com/Guide/MacBook...leaning/177920
                                          10-09-2024, 10:10 AM
                                        • claws77
                                          lenovo flex 5 14ITL05 laptop keyboard cleaning
                                          by claws77
                                          are there any resources that talk about cleaning keyboards thoroughly, by that i mean removing keycaps and cleaning.
                                          i am worried about breaking those keycaps or the plastic retainer clip.
                                          08-12-2024, 07:46 PM
                                        • loopster
                                          Need help cleaning ME region on Zbook 17 G1 bios dump
                                          by loopster
                                          Hello guys,
                                          could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
                                          Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
                                          I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
                                          Error 10: Failed to open with processed commands.
                                          Unable to open file: C:\Users\Elitebook...
                                          06-16-2024, 09:57 AM
                                        • howardc64
                                          LG 65UQ8000AUB no backlight burning smell
                                          by howardc64
                                          Only 3 years old. Owner said backlight went out and burning smell. Didn't bother plugging in to check if had power LED. Just opened the TV rear and found shorted bridge rectifier diode on the backlight circuit on the PSU. SF26G (400V 2A super fast recovery rectifier link ) diode replace with SF26 (what I had on hand) Google AI said G = Green Components.
                                          Burn looked pretty bad on the board but just was blackened carbon coating material. Scraped and cleaned off quite well and clean solder pad for the new diode.
                                          06-07-2025, 10:38 PM
