another $10 mac... G4 Tower
  • AudioCraZ
    • Sep 2009
    • 147
    #41
    Re: another $10 mac... G4 Tower
    FYI.
    I have done this before, but been a while.
    You can make an adapter cable to go from a standard 20 pin ATX power supply to a 22 pin iMac G5 mobo. If I remember correctly, you rewire the -12v and -5v pins on the connector to be +12v. The iMacs didn't use the voltage monitoring. The last two "extra" pins are +24v and -24v pins, which are only for the external vga port. For testing purposes, you don't need this, and I have personally never seen any iMac user having a secondary monitor.
    This is the iMac G5 22 pin ATX connector:
    This is standard ATX connector.pinouts.ru ATX Connector Pinout
    The standard ATX connector fits perfectly into the 22 pin plug on the mobo, just minus the two ports. Will only go in one direction as well, Hope this helps some people.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Originally posted by Scenic
      like colt said, use a different fan first.
      or a big passive heatsink.. remember.. the 120mm fan is blowing towards the cards
      otherwise.. here are original mac BIOSes and modified ones for flashing gfx cards..
      http://themacelite.wikidot.com/wikidownloads2
      read the flashing guides too.
      with the help of that site, i upgraded my G4 with a FX5200. now i can finally use DVI
      nope. it is a thermal adhesive heatsink. NO pushpins. it is not a standard fan.
      found a pic of an identical one:
      my other 128 HAS a big passive HS... but if it won't work, it won't. I do not feel like playing the hack and brick game with this.
      i checked the thread in general electronics about re-oiling fans; the blades do not rock, a drop of oil ought to fix it.
      sigpic
      (Insert witty quote here)
        • 31201
        if the blades dont rock then strip it, clean the shaft & oil it.
        but you could find another fan with the same bolt spacing - looks like a 40mm maybe.
        then mount the new one ontop instead of flush using longer screws.
        i used to get fans like that from old 486 type heatsinks at street markets & junk fairs.
        • seanc
          • Nov 2008
          • 1319
          #44
          Speaking of flashing cards, I need to see if I can flash my 9600LE to work in my G4 (and tape the pins).
          My machine won't power on if I have something connected to the DVI port :/ I have to power it on, then plug the monitor in.
          • Scenic
            o.O
            • Sep 2007
            • 2642
            9600LE? most likely not..
            http://themacelite.wikidot.com/fbg-9600
            • seanc
              • Nov 2008
              • 1319
              #46
              Oh poo
              I have two of those particular orange ASUS cards - I thought I might get away with the SE ROM, thanks for the link!
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                the assholes superglued the screws. what a PITA to remove. i got them out, looked under the sticker, dry. i will add a drop of oil.
                sigpic
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  sorry to d. post, edit will not work on my phone's browser...
                  will vegatble cooking oil work? it would be fresh...
                  sigpic
                  • AudioCraZ
                    • Sep 2009
                    • 147
                    #49
                    I think Vegetable oil gets corrosive over time.... or was that mineral oil?
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      i think it is mineral oil... my googling of vegetable oil come up with veg. oil as a anti-corrosion agent...
                      i will try it and see if it works.
                      sigpic
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        the oil is working... i hope it lasts!
                        sigpic
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          veg. oil will get gooey after a short time..
                          plus the fan may not spin up on its own when the card is cold, because its pretty thick. (once it seeped into the bearing)
                          i use vaseline when i have nothing else at hand and need to get a fan running..
                          • AudioCraZ
                            • Sep 2009
                            • 147
                            #53
                            What about something like air tool oil? That should be fairly thin...
                            • JOHNBOY
                              • May 2010
                              • 78
                              #54
                              A regular AGP car will not run on that. It needs to be a mac card incase you are trying to replace.
                              The fan on these is useless. You can tear it off and put a heatsink on it from any device. This is a $5 video card and it will make no diff. This same card actually comes in a heatsink version.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                yeah, i found the heatsink vs... it was out of a dell p3 box, has solder holes for a fan wire, i might see if it works.
                                sigpic
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  #56
                                  we go like 2 G4's at work a while ago. The main one I wanted to get working was a PPC dual 550mhz. I put like a gig in there and tried to put ubuntu on it. It worked with a default vga monitor hooked up, but when I tried it with the g4 monitor (the CRT one that is powered by the ati video card itself) it refused to output any video to it.
                                  so I managed to get my hands on panther 10.3. ran like S***T. even browsing the web in firefox or safari was crap. we just junked it
                                    • 31201
                                    should have used yellow-dog Linux,
                                    it's optimiised for ppc hardware.
                                    • JOHNBOY
                                      • May 2010
                                      • 78
                                      #58
                                      The 24v circuit in the power supply is dead if the ADC monitor doesn't work.
                                      The dual 550 with 1gb is actually half decent. I use a 867 and it does OK for basic stuff. The strengths of these powermacs is in audio and video, not trolling the web. I have an 867 that edits video but can barely play youtube.
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        if i want linux, i have 4-5 towers and a netbook that will do that. the mac is all i have that will do os x. I want osx to gain experience with working with mac os x, it looks good a resume for a part-time computer job (if linux skills were not enough).
                                        besides, i read somewhere that yellowdog is not free money-wise... correct?
                                        sigpic
                                          • 31201
                                          incorrect.
                                          each release is sold on dvd with a manual,
                                          then after a few weeks it comes available as a free download.
                                          you only pay if you want a book, support, or you want to be "cutting edge"
                                            HP Z240 Tower Workstation i7-7700 Specification for Upgrade or Repair
                                            This specification for the HP Z240 Tower Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z240 Tower Workstation boardview and Z240 Tower Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-12-2024, 03:44 PM
                                            HP Z240 Tower Workstation E3-1225V5 Specification for Upgrade or Repair
                                            HP 240 Tower E3-1270V5 Specification for Upgrade or Repair
                                            This specification for the HP 240 Tower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 240 Tower boardview and 240 Tower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP 240 Tower is accurate,...
                                            HP Z240 Tower Workstation i5-6500 Specification for Upgrade or Repair
