Which OS should I Use????
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Yes I'm getting one of Topcats Tyan Dual Opteron 64 bit CPU boards. Had to break the bank to do it. I going to get to learn lots of new stuff along the way. It will take some time for me to get the rest of the parts to make it go but it will be worth it. My first Questions are about which OS version to load on it to start out with. I have a "fixed" version of Windows Xp Pro Corp VLK. I would think that this is a 32 bit version and I don't know if it supports dual CPU's. I can take it all the way to Sp3 but the automatic updates will have to remain turned off. I also have my Dell Xp home 32 bit version but I used its COA on the AMD Thunderbird C sitting here. I also have a retail copy of Windows Media Center Edition 2005. Again I used its COD on another PC. Will Mr.Bill let me activate Media again on another PC? I have a Vista upgrade disk but its been installed on this Dell before too. In windows 7 I believe I have a "fixed" 64 bit version as well as a "fixed" 32 bit version. I would rather stay with Xp for now while I learn my way around this dual CPU animal. Windows Xp Pro 64 bit is still for sale but its still around $150.00 bucks. As it is I will need a case, PSU, ram and maybe other things to run the new one. Maybe I should buy the 64 bit windos Xp Pro while its still out there to be had....What do you all think on all that I have said???
    Mark Twain
    John Paul Jones
    Rod Serling
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Which OS should I Use????
    XP Home won't support 2 physical CPU's at all.
    XP Pro 32 and 64 will support the multi cpu's. The question of which OS you want will be determined by the amount of RAM you plan on running. The opterons support 64 bit, so no issues there. However, if you're not going to have more than 3gb of RAM, you have no need for 64 bit, 32 bit will be fine. FWIW, win7 would also run fine on this board, with enough RAM.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      Its going to be the 32 bit Xp Pro then. Would 1.5 gigs of ram on each cpu be about right? That would be three gigs total in the system. Have not given the manual a good read yet but I will.
      Mark Twain
      John Paul Jones
      Rod Serling
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Yes, that would be fine. Theres a 1gb and a 512mb stick coming with it. DIMM's don't interleave between the processors, so they can be safely mix-n-matched that way.
        For example:
        CPU1 can have a pair of 1gb sticks and CPU2 can have a pair of 512mb sticks.
        Team : 49813
        Join in!!
        Team Stats
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          That should be faster than two cpu's trying to use the same ram I would think. Going from my "318 v8 four door Dodge Dart" Dell to this unit just may be like jumping into a 440 dual powered 4 four speed 'Cuda. Even is it isn't it will at least have to be better than this pig. To Topcat!
          Mark Twain
          John Paul Jones
          Rod Serling
            • 31094
            put mandriva or suse linux on it - 64bit version.
            that will run duel-64bit cpu's well.
            then install an app called "wine"
            http://winehq.org
            then it will run almost any 32bit windows software too.
            • AudioCraZ
              • Sep 2009
              • 147
              Actually, of the "easy to use" linux distros, I have enjoyed Ubuntu. Come with a lot of installed programs, and has a software utility for finding a ton more, all free.
              Partition your main drive into 2, and throw both xp and Linux on it, you may be surprised that you like linux better. If it wasn't for my games and photoshop, I would be running only Ubuntu, just until I get more used to linux, and move on to Debain or Slax.
              I have rand Mandriva (Mandrake), and it is good, but I think for ease of use, and the "Ubuntu Software" program just beats it out hands down. Even with my current system, I run in it VMWare. Just a good round OS. Thinking of doing a dual boot with it, and actually doing a phisical install, and using it for my internet use.
              I swear, if Steam would make the move to Linux, Windows would be GONE.
              • AudioCraZ
                • Sep 2009
                • 147
                Sorry, got a little off topic on the previous post.
                As for moving CD keys, it is pretty easy, use the key with a fresh install. When you "activate" windows, it will either say "activation sucessful" or you will have to call Microsoft. Just call them, and if they ask if you bought the copy, or if it came with the computer, just tell them that your motherboard died, and you were forced to upgrade your computer. Right there, that tells them all they need to know why the hardware generated number changed so much. I move OEM cd-keys from computer to computer all the time like that. The one rule is one CD-Key per computer.
                Just FYI for anybody, you can find lots of windows cd-keys on ebay for around $8-$20 each for XP and Vista keys that are on "laptop battery doors", "laptop ram covers", etc... Cheap and easy way to get OEM cd-keys.
                Worked at several shops that did that, and you just have to tell microsoft that the motherboard died, and you are just upgrading your current system. (Tells them that the motherboard and other stuff was replaced in the same case, and by their terms of use, is completely within rules).
                • Junk Parts
                  Court Jester
                  • Jun 2006
                  • 8953
                  I have Ubuntu and Mint Gloria here. The Mint is ok but I'm no fan of linux. I'm stupid so I keep it simple. With Windows Xp in most cases I don't have to go download this or that to do the other. Mint is still on my Lappy along with Xp. I may boot to Mint and play around with it again today just for the hell of it. Yes its running "Wine" too.
                  Mark Twain
                  John Paul Jones
                  Rod Serling
                  • TheUser
                    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                    by TheUser
                    Hello to everyone ,
                    This is my first post here, and i would like to share with you a small story in case you can help me.
                    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                    02-10-2024, 02:07 PM
                  • sikocan
                    Lenovo X1 Carbon 9th Gen Black Screen
                    by sikocan
                    I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                    SN: PF3G1REP
                    MODEL: 20KW-00J1AU
                    PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                    Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                    06-24-2025, 09:01 PM
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • TJ65
                    Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
                    by TJ65
                    i made out of two broken Samsung Galaxy Tabpro S one that works partially.
                    The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
                    I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
                    The problem is, that the micom Version doesn't match with the bios version, see picture.
                    How can i update the Micom Version? The Samsung bios update wont work.
                    With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
                    01-09-2025, 01:35 PM
                  • thslr2020
                    [REQUEST] Modify BIOS version of dumped image(Panasonic CF-RZ6)
                    by thslr2020
                    Hello.
                    I keep tried unlocking FIVR lock(XTU, Throttlestop) to do undervolting, but failed. What I tired is...
                    1. Unlocked hidden menu >>> Disabled CFG lock, Overlock lock, SGX
                    2. Replaced CPU microcode to 2017, 2018 version (pre Spectre, Plundervolt)
                    3. Disabled Intel ME, Hyper-V & Vt-d
                    4. Removed microcode update of Windows(mcupdate_GenuineIntel.dll)
                    5. Try from fresh Win 8.1(boot with USB)
                    Even I already did all of above, XTU and Throttlestop is still locked. So I think what I can do is downgrade the BIOS version, but...
                    06-14-2023, 12:09 AM
