Athlon & SSE and SSE2
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    I've run into a little hardware issue with this Frankenputer I just put together. Its and ECS K7S5A mobo, 1ghz Athlon CPU, and 1 gig of ram. I like to watch movies on Netflix. To do this you have to have MS Silverlight installed. When I went to install it I got an error. The installer said that my CPU doesn't support SSE. What can I do to fix this? Can it even be fixed? My OS is Xp Home Sp3 fully updated and legal.
    Mark Twain
    John Paul Jones
    Rod Serling
  • Colt45ws
    • Jan 2009
    • 174
    Re: Athlon & SSE and SSE2
    Must be a Thunderbird Athlon. TBirds dont have SSE instructions. Easiest Fix is to get a Athlon XP or later Duron (Morgan or later)..
    • NxB
      • Feb 2009
      • 1595
      athlon xp starts at 1.3ghz. A 1.0 has to be t-bird or original. Max cpu is 2400+ because of the 133mhz fsb. You can get an athlon mobile and try to overclock it with the multiplier.
      I had the same motherboard, caps died and took the CPU with it.
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        I'll check into that. All it says under system in windows xp is Athlon 1ghz. I need to redope the heat sink on the CPU anyway. Whats a good price in the used market on this AMD Athlon Xp cpu that I need?
        Mark Twain
        John Paul Jones
        Rod Serling
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          Well NxB I guess its and old dog, and you can't teach and old dog new tricks. I did see some bios updates on the ECS site that were ment to make the board support faster, newer Cpu's. When I'm not so tired I will look at that stuff again.
          Mark Twain
          John Paul Jones
          Rod Serling
          • NxB
            • Feb 2009
            • 1595
            A cpu is like $6-10
            http://cgi.ebay.com/ws/eBayISAPI.dll...m=260425230618
            • Colt45ws
              • Jan 2009
              • 174
              The highest you can get is a "Throughbred" 2400+. There are 2600+ floating around but rare.
              That 2200+ will have the SSE instructions. Its a CPU thing you cant get it via BIOS updates, unfortunately..
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Originally posted by NxB
                funny how the pic in the auction shows a relabeled fake CPU (possibly a Geode or Sempron)
                the label print is way too far up and those specific CPUs don't have the datamatrix serial number anymore (the box on the right)
                auction
                http://i.ebayimg.com/09/!BT+hQggBGk~...eLi,Q~~_12.JPG
                real one
                http://www.cpu-world.com/Images/uplo...L_00000732.jpg
                • abbylee
                  Banned
                  • Jan 2015
                  This may help you.
                  http://answers.microsoft.com/en-us/w...2-5e6bb611b68d
                  • Junk Parts
                    Court Jester
                    • Jun 2006
                    • 8953
                    All the computers that I'm dealing with now have the SSE/SSE2 instruction sets. I gave way all the old stuff.
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      I recall having issues with my Athlon XP Thoroughbred because it was lacking instructions required in the newest Adobe Flash, seems like it needed SSE2 instructions or something rather...
                      Though something still seems wrong. I thought my Celeron (Tualatin) would have the same problem... but I thought it ran Flash fine... might be something else..
                      [EDIT]
                      No, it indeed does have the same problem and I retained the old Flash on it... Alas all of these machines are virtually retired now anyway.
                      • Junk Parts
                        Court Jester
                        • Jun 2006
                        • 8953
                        With my older PC's that didn't have the SSE/SSE2 instrucion set the progie that need same would alway warn me that the instruction set wasn't there.
                        Mark Twain
                        John Paul Jones
                        Rod Serling
