Good Fan Brands
  • c_hegge
    • Sep 2009
    • 5219
    Good Fan Brands
    While we have several threads mentioning fans failing and what they were replaced with, We don't have one with a list of good, reliable fan brands. From what I've seen:
    Good Brands:
    - Minebea/NMB
    - Panaflo
    - Sanyo Denky
    - Delta
    - Papst
    - Noctua
    - Nidec
    - AVC
    OK Brands
    - Sunon
    - Foxconn
    - Yate Loon
    Post what you have found with any other brands
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Good Fan Brands
    The Yate loons are the quietest I under volt the low speed ones to 5V and they are whisper quiet. They IMO are the quietest in their price range but they use sleeve bearings.
    If you want super quiet go with arctic cooling fans they have rubber shocks to absorb vibration and use fluid dynamic bearings like hard drives.
    On my new rig I used Yate loons 4 120mms and one 140mm. So the loss in CFM from undervolting is overcome by the sheer number of fans in the case. Feels like a summer breeze in there.
    • weirdlookinguy
      • Sep 2007
      • 1638
      Re: Good Fan Brands
      Adda fans look good but tend to seize up after some time.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Re: Good Fan Brands
        Originally posted by c_hegge
        - Sanyo Denky
        My favorite. They last forever!! Also are quiet.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • Behemot
          • 4845
          • CZ
          Re: Good Fan Brands
          The newer Delta fans are very good, the older ones use bad bearings and springs which causes vibrations. I recently acquired two 90mm Deltas, they do not vibrate on maximum speed (the rotor is centered than) but make terrible acustic nois; however they are still noisy when operating on 5 V due to the vibrations when not centered on low speed.
          The NMB are slightly better, but still not perfect. But what do you want from second-hand fans
          Only two really quite brands out there are Nexus and Noctua (=you hear vibrations at <=10 cm). Everything else is only close to quiet...AC vibrates, the Airen fans (which have won most reviews thanks to their price) vibrate even as brand new and are unusable after a year.
          • totalselfreliance
            • May 2010
            • 3
            Re: Good Fan Brands
            Yep, had this happen to one of my test machines as well.
            • c_hegge
              • Sep 2009
              • 5219
              Re: Good Fan Brands
              Arctic cooling and Scythe can probably be added to the list of good brands?
              • washu
                • Jul 2009
                • 310
                Re: Good Fan Brands
                Yep, all my quiet PCs are all Scythe or Scythe + Arctic Cooling. Never had any fail. I usually run them at 5V as well or use the PWM versions to keep them running slow unless absolutely necessary. My main desktop and 2 HTPCs are dead silent unless you get your ear within about 6".
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4981
                  • New Zealand
                  Re: Good Fan Brands
                  I've got 3 Sunbeamtech LED fans, they're a few years old and still going fine
                  They are quieter than others I have, Sunbeamtech claims 21dB (A)
                  -David VanHorn
                  • Behemot
                    • 4845
                    • CZ
                    Re: Good Fan Brands
                    I personally don't like Scythe fans because they have way too much unused room between blades. Maybe they are quiet, but blow too little...
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4981
                      • New Zealand
                      Re: Good Fan Brands
                      In my opinion fans are a trade off between Quiet\High Airflow\Small Size
                      You can pick only 2 at once...
                      -David VanHorn
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3112
                        Re: Good Fan Brands
                        Young Lin Tech are pretty good. Superred is hard to find, but pretty good. Ong Hua are also decent. Jamicon are actually pretty decent too.
                        Anyone have good luck with Fanner Tech (found under most masscool's)? I ran a couple in my computer for quite some time, they were actually pretty quiet and I didn't have any problem with them.
                          • 31090
                          Re: Good Fan Brands
                          i just cleared out a lot of fans - there where just too many!
                          kept all the ball type ones.
                          binned all the sleeve ones.
                          (including one that had a ceramic sleeve - not even bronze!)
                          Antec double-BB type fan's seem pretty good for the price.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Re: Good Fan Brands
                            uhhh... ceramic is better than bronze from what i heard...
                            sigpic
                            (Insert witty quote here)
                            • kikkoman
                              • Jul 2007
                              • 691
                              Re: Good Fan Brands
                              the ones I had were good. They were marked Fanner/Spire or similar.
                              "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                              • yyonline
                                • Jul 2009
                                • 692
                                Re: Good Fan Brands
                                I've found their ball bearing ones to be decent and last years. The sleeve bearing ones tend to get really noisy after a year or so, but at least they give some warning vs. just seizing up.
                                • AudioCraZ
                                  • Sep 2009
                                  • 147
                                  Re: Good Fan Brands
                                  I once had a Sanyo Denky Almost take the tip of my finger off.... It was love at first bite.
                                    • 31090
                                    Re: Good Fan Brands
                                    it's ceramics in the foxconn cpu fans that keep seizing.
                                    bronze bearings are oiled, ceramics arent.
                                    while stripping the crap fans i noticed something,
                                    the bronze bearings are the same dimensions as the ball-races.
                                    so i think i'm gonna get a cool looking chinese fan full of led's and swap out the bronze for some bb's for fun.
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      Re: Good Fan Brands
                                      When I started this thread, I was talking about reliability. So, even if Scythe don't always have the best blade designs, I would still consider them to be good.
                                        • 31090
                                        Re: Good Fan Brands
                                        reliability is simple,
                                        ball-race bearings will slowly get noisy but always run,
                                        bronze or ceramic sleeves will bind or even disintegrate causing the blades to seize - often without warning.
                                        so the bearings are what matters.
                                        now if your asking about db & cfm we can start praising and diss'ing different makes!
