I'm having trouble with the Dell laptop listed in my sig. Sometimes it refuses to turn on, instead giving me the power and HD lights and the Caps and Scroll Lock lights and then turn off after 10 seconds. Then, when it actually turns on, it freezes up after about 10 minutes in Win2000. I think it's a hardware problem. Input? I've called somebody and he says it's most likely the RAM, power, or heat. TIA
Dell Latitude trouble
Tags: None
Re: Dell Latitude trouble
internet search revealed ram problem with that model. one post even suggested bad solder joints on the board.
http://www.daniweb.com/techtalkforums/thread25744.html
boot problem suggests to me a post issue hardware related. if you hadnt mentioned the boot problem i would have said software issue/ram/hdd/heat. so we can basically eliminate software problem. i am guessing an age related hardware problem. was there any stability issue before the boot problems?
- if you have 2 sticks of ram then try booting with only one
- check the psu is supplying good voltage with a multimeter
- get hold of the dissasembly instructions to take a look inside (it is always best to proceed with them and carefully making sure you can put it all back together.
- once inside see if there is anything obvious
- clean out the vents and fan while you are in there
if it is the bad solder joints then you probably wont be able to see it
any more ideas guys? -
Freeze happens both on the battery and AC, startup prob happens only on AC. I only have 1 stick of RAM -- Samsung 128MB 8-chip PC100. Prob. will uprade as this stick seems poss. flaky.Comment
@Will: read your link but the MB seems to refuse start only within an hour or so of being turned off.Comment
no memory latency/speed settings anywhere in bios. finally got around to running memtest, froze after 23secs.Comment
Chris, I worked on a Latitude like yours, the owner had been rough on the USB port.
Kept pushing it up against the wall. After dissasembly he told me he had gold key agreement. The next day special delivery, Dell delivered a new motherboard.Sorry this isn't helpfull but you may examine all connections very closely.JimComment
Ah. Where can I find disassembly instructions for my Latitude?Comment
search on the net or pm some of the dell techs who visited here.
if you do disassemble, make sure you have a nice working place so you dont lose the little screws. i usually make a diagram on a piece of paper and place the screws on it so i dont mess up the reassembly.Comment
by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
Pictures of these boards:
Dell Latitude 5520 https://www.ebay.com/itm/256052956663
Dell Latitude 5530 https://www.ebay.com/itm/125844181534
Dell...4 Photos -
by F R 2568Hello all,
this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
If the laptop is only connected to the AC adapter (battery removed):
When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
The power/battery... -
This specification for the DELL LATITUDE 7520 CORE I7 11-1185G7 16GB 512GB SSD 15.6IN W10 CF NT WLS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LATITUDE 7520 CORE I7 11-1185G7 16GB 512GB SSD 15.6IN W10 CF NT WLS boardview and LATITUDE 7520 CORE I7 11-1185G7 16GB 512GB SSD 15.6IN W10 CF NT WLS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...09-06-2024, 10:50 PM
This specification for the DELL LATITUDE 7520 CORE I7 11-1185G7 16GB 256GB SSD 15.6IN W10 CF NT WLS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LATITUDE 7520 CORE I7 11-1185G7 16GB 256GB SSD 15.6IN W10 CF NT WLS boardview and LATITUDE 7520 CORE I7 11-1185G7 16GB 256GB SSD 15.6IN W10 CF NT WLS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...09-06-2024, 10:50 PM
This specification for the DELL Latitude 7320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7320 boardview and 7320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7320...09-07-2024, 02:50 AM
- Loading...
