best software to test a HITACHI 2.5" hard drive?
    • 31301
    like the title says.
    got a hitachi 2.5" drive out of a playstation3 that was acting weird - want to full surface-scan this drive.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: best software to test a HITACHI 2.5" hard drive?
    There's WinDFT for Windows or use the tools on the Hiren or Ultimate boot CD.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      Originally posted by diif
      ...or use the tools on the Hiren or Ultimate boot CD.
      I second this. Hiren's has helped be diag many flaky drives.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        • 31301
        well it passed with dft - so i suppose it's good.
        hard to trust something like dft though - it does not actually tell you what it's doing - it just has a progress bar.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Looking at the SMART attribute data is always a good idea.
          I like the software "HDAT2" for that.
            • 31301
            i looked at hdat2 but it was dos only so probably wouldnt detect a usb caddy
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              It does support some USB bridges, just not all of them:
              https://www.hdat2.com/hdat2_faq.html#q16
              Here is en example of an unsupported controller, but I can get it to work in Linux:
              https://www.badcaps.net/forum/showthread.php?t=55638
              • brethin
                • Dec 2008
                • 1907
                You don't say if t's para or Sara, but Hitachi has diags for their drives.
                  master hoarder
                  • May 2008
                  • 12175
                  ^ It's from a PS3, so it's SATA.
                  I concur with your suggestion, though - Hitachi does indeed have diag software for their HDDs. I think it was called "Hitachi Drive Fitness Test" or something similar.
                  yep, here it is:
                  https://www.techspot.com/downloads/5...ness-test.html
                  Not sure if that's the same DFT some of you talked about in the posts earlier above. But if not, see what this software says/does.
                  And indeed, just check the SMART data to get a better idea of what's going on.
                  Or even better yet, run a full (not quick) surface scan test with HDTune. I find that never fails to find bad sectors that are truly irrecoverable. It also gives you a map of where the bad sectors should be. I've used that info before to partition out big clusters of bad sectors on several HDDs and only create useful partitions with the good sectors. Worked with 100% success each time.
                    • 31301
                    if you find bad sectors on a ps3 you bin the drive, it's a custom format and you cant remap stuff.
                      master hoarder
                      • May 2008
                      • 12175
                      You mean bin the drive for PS3 use? Because I've reused a number of "bad" PS3 HDDs before in PCs. No problems there. One was a 40 GB Seagate that had over 1000 bad sectors, IIRC. I let the poor thing remap, then formatted and installed into a PC. Sounds like a madman thing to do... but the PC's motherboard actually croaked before the HDD. So it worked for my purpose. And it still works! IIRC, only the current pending sector count increased, but the bad sector count hasn't.
                      • tmcw
                        PC case - Hard drive rails
                        by tmcw
                        A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                        So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                        I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                        Now, the case is a CiT Gaming Case, and...
                        05-22-2022, 12:04 PM
                      • ash91
                        Hp pavilion 15 not detect hard drive
                        by ash91
                        Hello gentelmen .... this is my first post and sorry for my bad english,
                        so my proplem is my laptop keep losing hard drive even if i but the
                        hard disk in the cady (the box that can replace the dvd rom with hard disk)
                        when i turn the laptop on the massage that said no boot media found pop on
                        the hard disk is fine and to be sure i try another hard
                        i also update my bios to the last update
                        the 5 volt is present on the hard connector on the motherboard
                        the dvd rom work fine when i but a windows dvd in it
                        also when i boot from flash...
                        06-07-2023, 01:45 PM
                      • reformatt
                        Intel iMacs, 3rd party SSD failures and Fusion setups
                        by reformatt
                        I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                        As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                        So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                        12-18-2024, 10:34 PM
                      • federalhouse
                        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                        by federalhouse
                        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                        **Background:**
                        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                        **What I've Tried So Far:**
                        1. I accessed
                        08-01-2024, 07:03 PM
                      • karto95
                        Repairing a Seagate hard drive with damaged logic board
                        by karto95
                        I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                        I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                        If anyone has any suggestions or experience with this...
                        03-21-2023, 04:05 AM
