DSL Modem/Router
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    DSL Modem/Router
    My Son is giving me a new Linksys DSL modem router. What do I need to do to make it work with the Verizon DSL service? Is it as simple as just plug it up or do I need to call Verizons Tech to get it off the ground. I'm looking forward to using the Linksys because my Wetel is dying a slow death.
    Mark Twain
    John Paul Jones
    Rod Serling
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: DSL Modem/Router
    yeah you need to put some settings
    dsl login information
    username
    password
    and i forgot what other settings necessary but some of these definitely
    -encapsulation
    -vpi
    -vci
    -atm qos type
    can get these from your exisiting router if you can get to the menu
    this info probably on your isp site
    choose nailed up connection
    then you need to setup the firewall
    linksys are usually good with setup cds.
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      Ok Will it may not be exactly brand new so I don't know if it will come with a setup cd. I think I know where to get the current info on the Westel. There is and internet setup page for the thing. I'll go there and capture what I find.
      Mark Twain
      John Paul Jones
      Rod Serling
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        you dont need the cd you can use the internet setup page
        default url is usually 192.168.1.1
        username is blank
        password is admin
        although those are default settings
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          Thanks Mr Will. When on the Linksys page I take it I'll be able to disable the wireless side of the unit since I have everything hard wired here. Also do I need to setup a user name and a password on the modem/ router if its used in a hard wired system? I know there is something called WEP Incription that should be turned on or is WEP only needed on a wireless setup? Sorry I'm a numb nuts but a modem router isn't a car so I'm somewhat lost...
          As a side note the westel's LEDs are weak and blink all the time now. Its slow too. I think it has some internal issues. The unit is four or five years old now.
          Mark Twain
          John Paul Jones
          Rod Serling
          • NxB
            • Feb 2009
            • 1595
            Maybe the westel has bad caps. Wep is only for wireless and its easily crackable.
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              It just may have a few bad caps. I'll look into it after I get the linksys up and running. Can't be much inside that $19.00 Westel.
              Mark Twain
              John Paul Jones
              Rod Serling
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                yes you will be able to disable the wireless
                i dont see the need to setup username/pass if wireless not used but of course its better security
                wep is for wireless and it is easier to hack than wpa2 so i dont recommend that for wireless
                you will need to set up dhcp also so anything on your network can automatically connect to the net.
                so you enable that
                if your router is 192.168.1.1 then you make your starting address 192.168.1.2
                set your maximum users like 20 or whatever
                set your lease time to 0 minutes
                • Junk Parts
                  Court Jester
                  • Jun 2006
                  • 8953
                  I don't think the modem/router is the issue now. May desktop got to the point today where I could bearly get online with it. When I did get connected the pc would lockup when I switched from one web page to the next. I just deleted the partition, formatted and reprogramed that POS the other day in the hope it would fix the internet gremlins. I got so pissed that I hooked up the old laptop and now its working just fine on the internet. I think the LAN 10/100 onboard chipset has taken a dump in the desktop. I'll pick up a good PCI 10/100 card from my brother and see if that fixes it. I know to make sure I turn off the onboard 10/100 functions first.
                  Mark Twain
                  John Paul Jones
                  Rod Serling
                  • seanc
                    • Nov 2008
                    • 1319
                    I've a shuttle with that problem Junk Parts. It got to the point where it would barely do anything. Looked round the back, network card kept turning on and off.
                    I've changed all caps, even the network chip and swapped some crystals from other boards. No change for me
                      • 31087
                      did you check the shuttle psu?
                      • seanc
                        • Nov 2008
                        • 1319
                        Oh yes. Both Shuttle PSUs have been re-capped.
                        I've been testing with a re-capped Antec EA-380 as well - same issue.
                        I tried to replace the ports, but just can't get enough heat to melt the solder well enough for the tabs that anchor the casing of the ports to the board - perhaps a job for quikchip.
                        • Junk Parts
                          Court Jester
                          • Jun 2006
                          • 8953
                          Ok the Lappy ended up being just as sick online as my desktop. I did a little DSL speed testing this morning and here is what I got. On the Desktop.
                          Speed Test.net
                          Download 0.87 Mbps
                          Upload 0.33Mbps
                          Ping 60ms
                          First Verizon Test
                          Download 861 Kbps
                          Upload 330 Kbps
                          They had some sort of DSL optimizer on the site so I ran it. Here are the numbers after running the optimizer.
                          Second Verizon Test
                          Upload 853 Kbps
                          Download 429 Kbps
                          I have not used it enough to tell if their Optimization has helped anything. The second Verizon test numbers would make me think it hurt rather than helped me. Shouldn't Upload speed be the lower number and download speed be the higher number?
                          Mark Twain
                          John Paul Jones
                          Rod Serling
                          • seanc
                            • Nov 2008
                            • 1319
                            Well, how could it help??
                            You might as well crack the router open, even if you do find bad caps, its not going to die completely just because you can see them and it will work fine with the top off.
                            • MixMasta
                              • Feb 2006
                              • 142
                              You didn't mention what your Verizon DSL service speed is supposed to be. What is it?
                              • Junk Parts
                                Court Jester
                                • Jun 2006
                                • 8953
                                I have no idea. All I know is that it used to act much faster than it is now.
                                Mark Twain
                                John Paul Jones
                                Rod Serling
                                  • 31087
                                  make & model number - and open it.
                                  • willawake
                                    Super Modulator
                                    • Nov 2003
                                    • 8457
                                    • Greece
                                    open it and post a pic for chrissake
                                    • Junk Parts
                                      Court Jester
                                      • Jun 2006
                                      • 8953
                                      Its a Westel VersaLink 327W. No need for pics. I did take it apart and it has only one cap in it. It has lots of Ic's in it. The radio transmitter for the wierless is on a daughterboard that clips into its motherboard just like laptop ram. Its been working great all day ever since I ran verizon's configuration thing. I also did a simple repair that also may have solved the problem. I rebooted the dang thing.
                                      Mark Twain
                                      John Paul Jones
                                      Rod Serling
                                      • double_DD
                                        Why does my ISP router hate my "homemade" power supply??
                                        by double_DD
                                        It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                        So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                        For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                        07-12-2025, 03:09 AM
                                        HP ProBook 450 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook 400 Specification for Upgrade or Repair
                                        This specification for the HP ProBook 450 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Linksys Velop Intelligent Mesh WiFi System boardview and 450 G7 + Linksys Velop Intelligent Mesh WiFi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                        09-06-2024, 08:10 PM
                                        HP ProBook 430 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook 400 Specification for Upgrade or Repair
                                        This specification for the HP ProBook 430 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Linksys Velop Intelligent Mesh WiFi System boardview and 430 G7 + Linksys Velop Intelligent Mesh WiFi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                        HP EliteBook x360 1030 G4 + Linksys Velop Intelligent Mesh WiFi System Hybrid (2-in-1) Specification for Upgrade or Repair
                                        This specification for the HP EliteBook x360 1030 G4 + Linksys Velop Intelligent Mesh WiFi System Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Linksys Velop Intelligent Mesh WiFi System boardview and 1030 G4 + Linksys Velop Intelligent Mesh WiFi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                        09-06-2024, 07:50 PM
