Post your system.......
This is a sticky topic.
    Re: Post your system.......
    +12v is only CPU, Drive Motors, Fans & some of the Video.
    Chipset, the other IC's, Drive electronics, RAM, and all the rest are on 3.3v and 5v.
    +3.3@20A, +5V@20A, - probably isn't really.
    That 20a is the max assuming the other isn't doing anything.
    If you look at watts for combined 3.3v and 5v and do the math you can't achieve 20a on both at the same time.
    Mann-Made Global Warming.
    - Dr Seuss
      I'll check the label when I get home. I'm pretty sure it has combined specs on it. The numbers I got were just from a web search. Also, the 460 GTX has two PCIe power connectors, which are +12 and gnd, so I would imagine it's pretty heavy on the 12v
      Ludicrous gibs!
        Here's a shot of my home office as it stands now.. I still need to get a shot of the compute with the new SeaSonic PSU uploaded.
        Ludicrous gibs!
          Here's My Setup:
          Main Tower:
          Inside Shot:
          (A little tight in here I probably should have gotten a full tower instead of a mid tower, oh well, cooling is still fine just difficult to work in)
          Specs:
          CPU: Intel Core2Quad Q9450
          Motherboard: Gigabyte EP45C-UD3R
          Ram: Corsair XMS3 DDR3-1333mhz 8GB (2x4GB)
          Video Card: ATI Radeon HD5870
          Sound: Sound Blaster X-Fi Fatal1ty XtremeGamer
          Cooling: Cooler Master Hyper Z600R cpu cooler, 120mm case fan(rear), 80mm case fan(front)
          SSD: 128GB Samsung 830 Series
          HDD: Western Digital Caviar Black 1TB
          Other Drives: LG BH12LS38 BluRay-RW drive, Samsung SuperWritemaster DVD RW, 3.5" floppy, Memory Card Reader
          Other Cards: USB 3.0 card, TV Tuner/Video Capture Card
          Case: Antec Solution NSX4480B case
          PSU: Antec TruePower Quattro 850w
          OS: windows 7 Ultimate (64 bit)
          Server:
          Dell Poweredge 840 (Xeon dual core 3060, 4GB ECC DDR2-800mhz, 2X 1TB Western Digital [Raid 1], 80GB Seagate [OS Drive], Windows Server 2008R2)
          Computer Sound System:
          Some people use standard PC speakers, I use a vintage Marantz 2015 receiver and two Athena satellite speakers. I have yet to find any PC speakers that match the sound quality at anywhere near the price.
            Nice Marantz... I have a 2220b that used to be used with my computer, but I retired it pending a rebuild and refresh.
            Ludicrous gibs!
              Pics of my main PC's:
              Pictures are in this order:
              1) The Main setup
              2) The Model of my main PC
              3) The open side of the main rig
              4) The laptop opened
              5) The top of my laptop
              6) The never-been-shown-before DVD burner mod for my laptop
              7) The secondary rig
              8) The model of the ancient backup PC
              I also have many more PC's not shown.
                bump, more systems? I'll post mine later.
                I can put text here?!
                  epic stack of computers in the corner.
                  My Computer.
                  AMD APU A4-3300 2.5ghz 1mb cache
                  Motherboard GigaByte GA-A75M-S2V
                  Kingston HyperX Blue DDR3 8GB (2x4GB)
                  SB Audigy 2 ZS [B800] Sound Card
                  500GB WD Caviar® Blue™
                  1 Terabyte WD Caviar® Black™
                  2 Terabyte WD Caviar® Black™
                    id post mine but i need to clean my desk off first.
                    My Computer.
                      new cheap desk and not so cheap chair. monitor arm. led lighting under monitor.
                      1 main pc with also hdmi connection to tv
                      1 second pc with presently rgb connection to tv
                      both have wireless keyboards with touchpad also
                      two stereos. various shit. 1 plays only the top speakers. the other one plays 4 speakers
                      main pc and second pc and tv connected to the stereos with m-audio cards (2496 and 192)
                        Just stickied the thread.
                        sigpic
                        (Insert witty quote here)
                          Got a homebuilt:
                          Pentium Dual Core E5200 2.5 GHz
                          Biostar G31 board
                          2x1GB PC6400 RAM
                          WDC WD5000AAKX 500GB SATA
                          Plextor PX-880SA DVD-R
                          Nvidia GeForce 8400GS w/512MB
                          Viewsonic VA1912 19" LCD monitor (waiting for part to finish repair)
                          IBM 42H1292 PS/2 keyboard
                          Windows 7 Ultimate x64
                            thats a little weak, hope you're not planning on playing bf3 on that
                            so you got suckered into buying win7 ultimate? There is so much shit you don't need and won't use, you could of put the $$$ into a better video card
                              Is that an ashtray on your table?
                              Do NOT touch heatsinks when testing for voltages as they may be LIVE!
                                Originally posted by Per Hansson View Post
                                AXMH2500FQQ4C Z40091SB40131
                                IQYHA 0409RPMW
                                I've used both a Epox 8RDA3+ and a Abit NF7-S with it
                                2.3ghz was on Air too....
                                That's nothing for that type of Barton! I'm already at 2.4 with a regular Barton.
                                And 2004 T'breds can do 2.3 easy. Earlier T'breds should hit 2.25 at least.
                                Unless it's an "AIUCB", which consistently are low rank in OC databases and my T'bred 2000+ AIUCB 02xxx couldn't even do 2055 Mhz without Prime95 giving me an error. And at 2055 Mhz, I also will get a "STOP: 0x0000009C MACHINE_CHECK_EXCEPTION" BSOD when playing Goldeneye.
                                There's a wall at roughly 2050 Mhz.
                                And at 2.1, it only made it to the Windows desktop once! Within approximately 1 minute, get Windows XP pop-up "Windows Explorer encountered a problem and needs to close" and then rebooted on me. And then afterwards, at 2.1, the Windows boot loader usually reported NTOSKRNL.EXE being missing or corrupted or just fails to POST. Windows 2000 (A different run) wasn't actually corrupted. The boot loader just kept spitting out that error message, because it was xtremely unstable.
                                My 2004 T'bred 2400+ KIXJB was much better, 2.25 Ghz only required 1.70V with Prime95.
                                And 2.37 Ghz was a sweet spot for my 2400+ KIXJB, didn't require more than 1.75V for Prime95.
                                2.4 is tricky. But, I was able to run some Prime95 without an error or crash back in August, 2004 with 1.85V, IIRC.
                                ASRock B550 PG Velocita
                                Ryzen 9 "Vermeer" 5900X
                                Sapphire Nitro+ Radeon RX 6750 XT
                                eVGA Supernova G3 750W
                                Alienware AW3423DWF OLED
                                  Nice setup. I like the apartment too - looks really cozy .
                                    Primary laptop
                                    Thinkpad X201
                                    Intel Core i5 (2.4GHz, 3MB)
                                    3GB RAM
                                    Ubuntu 12.04
                                    Gaming PC & temporary media PC
                                    Custom build
                                    AMD FX64 X2 (2.8 GHz stock)
                                    Abit KN9 Ultra motherboard
                                    2GB RAM (all I had left...)
                                    Nvidia 9800GT
                                    Windows XP
                                    Future build: Media PC
                                    Custom build
                                    AMD or Intel processor
                                    Any motherboard I can get
                                    Whatever RAM I can scrounge
                                    A hard drive
                                    Zero to two fans
                                    Gigabit ethernet
                                    XBMC highly customised
                                    Windows XP or 7
                                    Going to also use a Raspberry Pi as the "basic" HTPC for the basement mancave with basic XBMC support, all files network streamed.
                                    Future build: Media server
                                    Custom build
                                    Old processor (performance noncritical)
                                    1 GB~2 GB RAM
                                    Multiple drives in some RAID config
                                    Gigabit ethernet
                                    Windows XP or Ubuntu
                                    ^Purpose will be simply to download requested files, store them, and stream them on demand to the media sinks (HTPC, laptop, desktop.)
                                      Thought I'd share my computer desk/ iRacing sim rig. I just got it together so please excuse the wiring mess until I get started on some creative hiding of wires.
                                      Computer:
                                      Asus Sabertooth Z77
                                      i5 - 3750 to 4.5g watercooled (cpu only)
                                      16g corsair ram
                                      SSD
                                      4g 670gtx SC - SLI
                                      Rosewill 1000w PSU
                                      3x Acer 120hz w/ nvidia 3dVision2 (kid loves 3d but it hurts my head)
                                      Klipsche speaker system/ sub (hate it)
                                      Turtle Beach headset
                                      Sim Rig / Desk:
                                      Obutto R3volution w/ triple monitor stand and articulating trays
                                      iPad for telemetry
                                      Fanatec ClubSport Wheelbase (quick release system)
                                      Fanatec ClubSport V2 pedals
                                      BMW wheel
                                        AMD FX8320 Piledriver SKT AM3+
                                        Zalman CNPS9900-MAX Cooler
                                        Asrock 970 Extreme3 Mobo
                                        8GB Kingston Predator Beast DDR3 1600mhz RAM
                                        AMD HD 6970 Graphics Card
                                        500GB Sata III Seagate Barracuda HDD
                                        Powercool X-Viper Modular 750W Power Supply
                                        NZXT Lexa S case
                                        Once repaired Goodmans LD3265D2 32" LCD screen
                                          Primary:
                                          HP heavy tank case
                                          AMD Athlon 64 x2 5000+ dual core 2.61ghz
                                          HP SlimLine triple heatpipe copper heatsink modded from socket 775 to am2+
                                          Asus A8M2N-LA mobo
                                          2gigs of ddr2
                                          3 250gig sata 2 drives (hitachi,hitachi,wd)
                                          ATI HD5450 512mb overclocked, oven baked (gpu fail), fan modded onto heatsink, replacing my dead hd4850 currently, will get a hd 6870 soon.
                                          Creative SoundBlaster xtreme fidelity xtrememusic
                                          some kind of a pci wifi card
                                          Delta dps-460db a 460w psu (good one)
                                          lg dvd drive
                                          Second system:
                                          AMD athlon 64 3400+
                                          1.5gb ddr
                                          geforce 8400gs pci-e
                                          lg dvd drive
                                          asrock board
                                          80gig ide (ata) hdd
                                          a good looking small case that i will probably plant my main system into
                                          medicore 350w codegen psu (not too bad actually, not a huge pile of shit like other codegens, even has PFC, will get replaced probably)
                                          There are many more systems but im too lazy to list them.
                                          1st rig will be upgraded soon.
