I'm laughing at HP!
  • Newbie2
    • Sep 2005
    • 885
    I'm laughing at HP!
    This is similar to Fatal0E's thing about ABS Computer, I took off the heatsink that was on the processor because I wanted to reduce the temperature of the processor (The HP case is tiny and cramped) a bit and when the heatsink was removed I saw the plastic "Remove before use" pad. HP, leaving the "Remove before use" pad on the thermal pad of the heatsink is bad!
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
  • bushytails
    Moderator
    • Dec 2004
    • 217
    Re: I'm laughing at HP!
    Your signature is too long. make it shorter.
    --Randy
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      I'm always laughing at HP when I see some joker buy one and realize how shoddy it is..... I also laugh when their caps go bad, which is even funnier!
      Ohh well, I'm spoiled by my Supermicro X5DAL-TG2, which is immune to the bad caps plague............................opens case just to be sure...
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        We used to buy HP, but when they bought Compaq and it was reported that HP desktops would be designed in Houston (Compaq) instead of Sunnyvale, we decided to switch. I'll continue this in the "Post Your System" thread.
        PeteS in CA
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • Ven
          Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
          by Ven
          I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
          The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
          I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
          If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
          07-08-2024, 09:32 AM
        • longmt1990
          Panasonic Cf-w5 bios password remove
          by longmt1990
          Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
          I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
          Please help me remove bios password.
          Thank you so much
          07-06-2025, 10:50 PM
        • Maxpower3
          Hantek 365 Remove screen on startup
          by Maxpower3
          every time I open the tool, I have the screen that appears
          and I am always in a hurry to use it so I click and it automatically sends me a link to the manufacturer.
          It annoys me lol.
          2 solutions to remove it.
          Either you remove pic.bmp and it no longer appears so no more links when clicking.
          hope this helps users...
          01-15-2025, 03:24 PM
        • piernov
          Core 2 "gaming" build with SLI
          by piernov
          My turn to post a build I guess, wasted way too much time on this one…
          First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
          Everything done with random parts I had lying around.
          Specs :
          • CPU: Core 2 Quad Q9450
          • RAM: 2x2GB KHX6400D2K2
          • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
          • MB: P5N-E SLI
          • PSU: Antec Basiq Power 550 Plus
          • HDD: Hitachi Ultrastar A7K2000 1TB
          • ODDs: DVD ROM, DVD RW
          • Case: not sure
          Cooling:
          • 92mm rear fan
          • 120mm front fan
          • Additional heatsink on southbridge
          05-20-2023, 11:38 AM
