Socket 940/939 Cooler bracket failure
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Found some missing pieces (thumbscrews) to one of my retired rigs, my dual Opteron X2 Socket 940 rig, went to move it to replace them, and made an unfortunate discovery:
    The freaking plastic heatsink bracket sheared off while sitting. Thank goodness that didn't happen when it was running!
    I removed the thermal compound before shooting that... it wasn't until after that I figured out why the cooler came loose, right as I was about to apply fresh
    I have some Dead/Disused socket 940 stuff floating around if I want the cheap way to fix... anyway, anybody know of who/what makes for a better cooler bracket?
    sigpic
    (Insert witty quote here)
  • linuxguru
    • Apr 2005
    • 1564
    Re: Socket 940/939 Cooler bracket failure
    I've seen this happen before. The metal integrated heat-spreader varies in height between Socket 939 and Socket AM2/2+. It looks like the HSF is interchangeable between the two, but the difference in the IHS height sometimes increases the stress in the plastic retaining bracket when the HSF is locked, causing the tab to snap on occasion. You can replace the whole assembly from a dead or flaky mobo if available.
    There's an alternate heat-pipe stacked-fin cooler which uses the cabinet airflow, instead of a mounted fan, to cool the stack. I had that on a DFI Lanparty SLI board with a S939 Opteron 165, now retired. I'll take a pic in due course.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      you can literally replace it with another bracket from a 939/am2/am3's motherboard
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16955
        The tabs breaking off a socket370 meant the kiss of death... That one can easily be replaced. The socket-A/462 had the 3-tab sockets, and were pretty tough if using a heatsink that grabbed all 3.
        939/940/AM2 were like skt478 brackets...broke easily, but cheap and easy to replace.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Yeah I know it's replaceable... that wasn't my question. My question was more along the lines of "is there a particular brand or style that is less prone to breakage"?
          The coolers are Cooler Master TX3's, for the record.
          sigpic
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16955
            The socket brackets are pretty universal like a P4 skt478 bracket is... If you need a replacement, just say the word, I've got a bunch of them. Are they prone to breaking? I've seen a few....but it wasn't a really big problem.
            Team : 49813
            Join in!!
            Team Stats
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              I have some on dead/defunct boards... Just seeing if there's something to look out for when picking a replacement.
              sigpic
              • RJARRRPCGP
                • Jul 2004
                • 6301
                Back in 2001 and 2002, I only had a heatsink for socket 462 that connected to the middle tabs! Especially with a T-bird when gaming, losing a middle tab was death for them!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3261
                  • Singapore
                  some companies like scythe, came up with metal heatsink mounting brackets for s478 and 775. ditto for 754/939/am2(+).
                  TechPowerup - Scythe enhances Cooler Mounting: CPU Cooler Stabilizer 775 replaces Push Pins
                  Quiet PC - Scythe CPU Cooler Stabiliser 775
                  TechPowerup - Scythe Brings In CPU Cooler Stabilizer for AMD Sockets 939, AM2
                  Quiet PC - Scythe CPU Cooler Stabiliser AMD
                  funny how the japanese always come to the rescue everytime someone else comes up with shitty aesthetics for their products!
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Shame, they seem to be unobtainium... otherwise I'd buy four, for the two of my three AMD systems that could use such (I have a socket F system with the same TX3 coolers; my socket 940 server has Screw-down dynatrons that don't have this issue!)
                    sigpic
                      • 20318
                      They made an updated version called the Scythe Universal Retention Kit III, frozencpu seem to have some in stock
                      https://www.frozencpu.com/products/2...2_AM2_AM3.html
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Good find. Noted... will probably get me some.
                        sigpic
                        • BleedCap
                          OLD Socket 478 custom bracket + NEW generic cooler
                          by BleedCap
                          I already posted this on vogons.
                          Its a 3d printed custom bracket for socket 478.
                          I used this AM4 bracket as a base design.
                          Its to be use with cheap generic clip based cpu cooler.
                          Reason for doing this is:
                          - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                          - New generic cooler is cheaper and can use bigger fan (less noise)
                          I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                          The processor that I was using is P4 2.4Ghz prescott....
                          11-05-2023, 08:09 PM
                          12/24 volt compressor cooler box inverter capacitor failure
                          by sam_sam_sam
                          This is my son’s cooler for his semi truck for his drinks the other day it started short cycling ( running for a second or two then shutting down ) and restarting four or five times then going into an error power cycle the controller then it would do the same thing again
                          Found a 47uf@63 volts double the ESR value of a new one
                          The 220uf@16 volts same as a new but 220uf@35 volt replacement capacitor
                          The main filtering capacitor was not replaced because I did not have that was not too tall
                          Where the 220uf capacitor is some type of switching power...
                          08-30-2022, 05:28 PM
                        • Isabella91
                          Possible to convert eMMC Socket to a micro SD Card socket?
                          by Isabella91
                          I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
                          Read/Write a Micro SD Card from an eMMC Socket.
                          I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
                          Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
                          Not to remove...
                          01-14-2024, 05:10 PM
                        • warsztat
                          Acer AN515-57-577G JDIMM1 socket not working.
                          by warsztat
                          Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
                          11-18-2024, 09:13 AM
                          HP EliteDesk 800 35W G2 Mini + EliteDisplay E242 + PC Mounting Bracket EliteDesk 800 i5-6500T Specification for Upgrade or Repair
                          This specification for the HP EliteDesk 800 35W G2 Mini + EliteDisplay E242 + PC Mounting Bracket can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 35W G2 Mini + EliteDisplay E242 + PC Mounting Bracket boardview and EliteDesk 800 35W G2 Mini + EliteDisplay E242 + PC Mounting Bracket schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                          09-12-2024, 03:28 PM
