USB inputs fail
  • ramondo
    Confused Member
    • Jun 2015
    • 39
    USB inputs fail
    I have an older Dell Optiplex 960 Windows 7 system that has been running fine for several years. Lately all Usb inputs have randomly stopped working (keyboard and mouse not recognized). I have run AV and SFC and MWB with nothing found. It does not matter which program is running (even in the middle of Solitaire) when problem occurs. Restarting PC does not fix the problem. Cannot enter BIOS SETUP MODE. However unplugging pc from wall power and replugging fixes problem for several days. Where should I look first to solve this problem,, or what actually gets depowered when unplugging a PC that is in the OFF state.
    Thanks to all for being__WAR_KITTENS____!
    • 31214
    Re: USB inputs fail
    check the inside of the power supply for bulging or leaked capacitors.
    i have seen this when the 5v standby voltage goes to shit.
    dont ignore it - it can eventually damage the motherboard.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      Re: USB inputs fail
      also check your device manager for code 10's on the USB controller
        master hoarder
        • May 2008
        • 12175
        Re: USB inputs fail
        I second this notion - I've seen bad caps on the 5VSB make USB and PS/2 devices drop out or act up. Given that it's a Dell, it probably has a Delta, HiPro, or LiteOn PSU. Many of those utilize CapXon, Teapo, and Ltec caps - none of which tend to last in the long run (especially the Ltecs)... which is a shame, because those PSUs are otherwise well-made. I usually recap them, though. After that, they are pretty much bullet-proof (save for a few specific models that do have known problems - but even these tend to be reliable overall.)
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          Replaced emmc.
          Terminal log
          UART
          AC_ON
          E-B
          FDE enabled
          06-01-2025, 02:11 AM
        • C152Heavy
          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
          by C152Heavy
          Summary for TL-DR readers:
          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
          • Have obtained Samsung schematic & service documents - Can upload if helpful.
          • Have read ALL applicable threads
          • C1818 and CP820 replaced as low hanging fruit
          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
        • dragometin
          Hitachi 40HYC42
          by dragometin
          TV Model: Hitachi 40HYC42
          Power Supply: 17IPS71
          MainBoard: 17MB95M
          Panel: VES400UNDS-2D-NO3
          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
          Is there any variants on 17IPS71 power supply's?
          UART output pins 10 and 12 on scart connector:
          Code:
          12:24:04.595
          08-08-2024, 05:53 AM
        • Perry Babin
          Capacitors of the same make/series that consistently fail in one amplifier while they rarely fail in a different make amp
          by Perry Babin
          This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be?
          04-03-2024, 10:40 AM
        • remizbushka
          Dell inspirion 5775 bios "Unlock Setup fail"
          by remizbushka
          Hi sirs. please help
          Dell Inspiron 5775 bios locked "Unlock Setup fail"
          After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
          What I did:
          I read the bios dump.
          Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
          03-24-2025, 09:07 AM
