What's the worst brand of PSU?
  • c_hegge
    • Sep 2009
    • 5219
    There seem to be a few PSUs that are dreaded among the members of these forums. Deer, Sun Pro, the Worstecs with the killer 5vsb, Fuhjyyu'd antecs (before a re-cap), Powmax, etc. Which one do you think is the worst? I'd have to say the Fuhjyyu'd CWT made Antecs as I've seen more of them take boards out than any other brand
    41
    Deer
    14.63%
    6
    Sun Pro
    4.88%
    2
    Powmax
    29.27%
    12
    L&C
    9.76%
    4
    Fuhjyyu'd antecs (Before a Re-cap)
    21.95%
    9
    Woestec (Bestec) with killer 5vsb (Before a re-cap)
    12.20%
    5
    Other
    7.32%
    3
  • toastygoodness
    • Jul 2005
    • 813
    Re: What's the worst brand of PSU?
    i'm pretty sure nothing gets worse than Deer and its brethren
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      sun pro. some sun pro units had only 1/2 a pcb, and an echo star made by sun pro had weights inside to make it seem more like good quality (it had a half board.
      a-power, leadman, and powmax are tied for a close second as they at least use a full or near full circuit board in all units,
      all units up to here are non-fixable junk. past here is repair hope.
      deer 3rd. at least deer can be recapped/ fixed 1/2 the time.
      the rest are great after a recap/ minor solder mods.
      sigpic
      (Insert witty quote here)
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        I said powmax. Deer/solytech/L&C has stepped up their game and actually make good units with teapo caps now. Leadman/powmax is still down there.
        http://www.hardwaresecrets.com/article/666
        This unit could deliver its labeled 600 W at 52º C, which is wonderful, plus we could pull up to 746 W from it, and it survived!
        The article number is 666!
        • cheese007
          • May 2009
          • 85
          Anyone ever seen a Linkworld psu?
          http://www.jonnyguru.com/modules.php...tory3&reid=123
          Yeah.
          • toastygoodness
            • Jul 2005
            • 813
            ahh i forgot about leadman....
            • everell
              • Jan 2009
              • 1514
              For Antec and Bestec, if you recap AND modify the 5vsb circuit with a pwm chip, they are great power supplies.
              I vote for Powmax as worst - I don't think there is much you can do to improve it ... short of a sledge hammer!
              Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                worst i have seen was an okia with the half board.
                looked like a 150w itx power supply guts.rated at 500w.
                gutless as it gets.
                  master hoarder
                  • May 2008
                  • 12175
                  Would have said PowMax, but some of the older ones are actually not that bad. The newer ones are crap, though. But I doubt anyone will beat Sun Pro.
                  https://www.badcaps.net/forum/showpo...2&postcount=36
                  I have a 380 watt Raidmax PSU made by Sun Pro and it's very similar to the one in the above link. Same PCB burn, too. Obviously they weren't designed properly. 1mm thick heatsinks don't help much either. Not to mention that PCB spacing on the primary side is non-existent between traces.
                  I must say, however, that I do believe that Sun Pro and PowMax are related. Some of their designs are way too similar, not to mention the identical "7700" transformer markings on certain models.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    Leadman and powmax are one in the same. seen many of them incinerate themselves. also seen way too many bestecs roast boards. Bestec would get my vote as the worst. As crappy as deer, powmax, and the others may be, I've never seen any of those cook motherboards as frequently as bestec.
                    <--- Badcaps.net Founder
                    Badcaps.net Services:
                    Motherboard Repair Services
                    http://folding.stanford.edu/
                    Team : 49813
                    Join in!!
                    Team Stats
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      I'm actually buying a solytech sl-9600 from a guy who gets them from the 80plus organization. It's solytech's most efficient model and is 80plus silver certified. Even reaches 89% efficiency at 50% load, 87% at full (600W)
                      Voltage regulation from the 80plus's report is even very good, 5v and 3.3v, even -12v don't budge and the 12v stays at 12.3 until full load where it is 12.2.
                      • washu
                        • Jul 2009
                        • 310
                        I'm torn between Bestec or pre-recap Antecs.
                        I've seen lots of Bestecs kill MBs but usually that's all they kill. The CPU and other parts usually survive.
                        Not so when Antecs kill. Despite my warnings, my co-worker was building a new PC and fried the following with his SP-500 that he insisted on keeping: i7 860, MB, RAM, 3 HDs, and an Nvidia 7900. The only part that survived was his DVD drive. The CPU then killed 5 more MBs at the shop.
                        • larrymoencurly
                          • Oct 2004
                          • 960
                          sun pro. some sun pro units had only 1/2 a pcb, and an echo star made by sun pro had weights inside to make it seem more like good quality (it had a half board).
                          Wow. I have some Logitech mice with weights inside them, but they're to make the mouse movement feel better.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            see: https://www.badcaps.net/forum/showthread.php?t=6341
                            sigpic
                            • acstech
                              GrumpyModerator
                              • Jul 2007
                              • 1432
                              Hey, somebody actually agrees with me!
                              Bestec =
                              A man convinced against his will is of the same opinion still.
                                • 31159
                                the worst are Antec - no contest.
                                the reason is simple,
                                a 15€ shit supply looks like shit, and feels like shit.
                                Antec are different, they feel good, look good, are expensive and marketed as high-end.
                                this fools people into trusting them.
                                i'v even seen people "upgrade" FSP stuff with them!
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3112
                                  Well, new antec's are delta and seasonic, both are a upgrade from FSP (for the most part,) but antec has a nasty habit of slowly decreasing the quality of caps in their units.
                                  • seanc
                                    • Nov 2008
                                    • 1319
                                    Back in 2007 I had 4 Antec EarthWatts 380w in a batch of PCs I was building either not work or blow up.
                                    I had one of the few working PSUs of that batch fail a couple of weeks ago and opened it up, it looks pretty anemic, compared to what I was expecting and it's full of OST caps, which I need to remove, test and possibly replace. All visibly fine.
                                    I've not had any fail since that bad run so I'm guessing they changed OEM or sorted their previous issue out. If one of the more recent PSUs fails, I'll update you.
                                    • goodpsusearch
                                      • Oct 2009
                                      • 2850
                                      • Greece
                                      I voted antec.
                                      My first 2 psus were Antec true power 380W and Linkworld LPQ300W .
                                      The difference is obvious:
                                      The linkworld and every other same category psu doesn't cost more than 15 euros (usually comes free with pc case) and you always know it is not a quality supply.
                                      On the other hand, antec costed me 107euros back then in 2003, and I bought it concerned about my hardware's safety and chose antec after having read reviews all over the internet (tomshardwre etc) that recommended it.
                                      It died 2 years later and so did a hard driver and an ati all in wonder 9700pro. It was sent back through rma and I recieved a true power version 2.0 psu that had also Fuhjyyu caps that also bulged and maybe killed my all in wonder 9800 at August 2009 (can't be sure about that thought).
                                      The funniest thing is that the cheap linkworld still works, has no bulging caps and is powering a pentium 3 pc.
                                      • kaniki
                                        • 514
                                        I have a hercules 400 or 450 watt power supply in a computer that i built for my mom about 5 years ago. That was a cheap power supply too and still going strong.. Just checked voltages (all fine) and even opened and all caps looked fine (did not check with meter, just eyed). not too bad for a cheapie.. on a bad note, it is a albatron (if i remember right) board and guess what, 3 3300uf caps, all bad and leaking, and 5 6.3v 1000uf (4 are starting to round out) caps. got some samxon for the 3300's and ruby's but 10v for the others on the way. this is what i got for upgrading her computer.. she had a 5200 vid card and upgraded it too a 6600 overclocked series.
                                        but back to the power supplies, my question is, how has the hercules power supplies been? have they been known to blow after so many years? The only problem i have found with mine so far is I had to grease the fan once (got it before it stopped, but was getting noisy).
                                        • kotel studios
                                          DEER B350ATX PSU - tips on making it safer and "better"
                                          by kotel studios
                                          Since it looks like my excellent power PSU chances at living are now close to zero, I decided to give a shot at upgrading this DEER B350ATX PSU.
                                          At first glance it looks like, well.... a shitty cheaped out DEER garbage (cause it is). Although it does have an LF 1250CD00 filter transformer (at least I think that's what it is) 😆
                                          Tiny heatsinks, small transformators, single-pole ON/OFF switch. You name it.
                                          Now since this one works, I'd like to know how can I make it safer and better (besides burning it with napal 😃). My plan is to make the switch double-pole...
                                          03-04-2025, 12:09 PM
                                        • nomoresonys
                                          The worst poorly constructed tvs that are being churned out.
                                          by nomoresonys
                                          This topic might save some from buying the worst of the cheap tvs. Have seen plenty, this is the latest one I've had the dis-pleasure to see up close: Hisense 55-Inch Class A6 Series 4K UHD...
                                          03-03-2024, 07:01 AM
                                        • Rayblaster
                                          HP RP7 RP7800 from 2012/2013 worst fault - has "character"
                                          by Rayblaster
                                          Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
                                          I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
                                          12-30-2024, 06:28 PM
                                        • reformatt
                                          A1466....worst blown PCH I have seen
                                          by reformatt
                                          Check this out for a catastrophic failure of the PCH on this 820-00165 board.
                                          PP3V3_S5 had a 11 ohm short to ground and the PCH +1.05V coil was dead short. Took off the heatsink...didn't expect to see the cap completely shattered.
                                          There was some bug crap and liquid ingress over the board. There was something stuck to that 2.2 ohm resistor on the 1.05V buck converter. But the real damage I believe was the crap on U7501, as those pins were for the feedback for PP3V3_S5.
                                          Initially I thought this was a board destroyed by bug shit, but the trackpad is also not...
                                          02-08-2022, 04:30 AM
                                        • shovenose
                                          Spare Parts + eBay's Finest = Worst Gaming PC of 2021?
                                          by shovenose
                                          Alright folks, today I present my latest "build", consisting of mostly spare parts with a few things off eBay.
                                          Parts List and Pricing
                                          CPU: 3/0GHz 4C/4T Intel Core i5-7400. Nothing exciting here, got it off eBay for $80.
                                          RAM: 16GB (2x8GB) Corsair DDR4-2400. Had it floating around. Free.
                                          Motherboard: Gigabyte B250M-Gaming 3. Because I had it floating around and the model number contains gaming so it must be better, right? Free.
                                          Storage: 240GB WD Easystore SSD. As far as I know, it's just the Best Buy rebadge of...
                                          12-21-2021, 08:34 PM
