SATA PCI Card
  • Roadkill203
    • Oct 2008
    • 68
    SATA PCI Card
    Looking to add a cheap SATA PCI card (4 port internal SATA, no external SATA) to my system; I saw a bunch on Newegg for anywhere between 30 to 50 dollars (US)... I'm not looking for a RAID controller, just looking to add a few SATA drives and a SATA optical drive. Any suggestions on the manufacturer I should go with? I'm leaning towards Rosewill HERE or Siig HERE ... Any input would be appreciated!
  • washu
    • Jul 2009
    • 310
    Re: SATA PCI Card
    I have a Silicon Image 3114 card in my backup file server. It's nothing special, but it works fine. I forget which brand it is, but most of them are pretty much the same.
    Just be aware that it won't give you anywhere close to the performance of an integrated chip set or PCIe controller. The PCI bus is the limiting factor. I also don't know if it supports optical drives, I've never tried.
    • Christos Tsiligiannis
      Marian Trace Alpha sound card repair help
      by Christos Tsiligiannis
      Hello to the forum.
      My name is Christos, I am new to the forum here and i am posting from Greece.
      So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
      To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
      So i tried asking for a schematic from the company and they would not give me one. Instead they...
      11-18-2024, 05:26 AM
    • Kemer
      Graphics Card mounting frame
      by Kemer
      Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
      As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
      I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
      What worries me right now is the possibility that...
      09-14-2024, 08:57 AM
    • FZG
      EVGA Nu Audio Sound Card - Not Working
      by FZG
      I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
      The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
      I found...
      03-07-2025, 11:44 AM
    • benwaterson
      Gigabyte Aorus 1080ti - card not initialising
      by benwaterson
      Hi there.
      Have searched various forums but haven't come across the exact issue I am having.
      Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
      I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
      Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
      02-05-2022, 11:42 AM
      Alcor AU6368 USB 2.0 Flash Memory Card Reader Datasheet
      The AU6368 is an integrated single chip memory card reader controller specially designed for notebook, hand-held and other PC peripheral devices, which require fewer components for small PCB area. It supports a widely used flash memory card such as CF, MD, SMC, xD Picture Card, MS, MS Pro, MS Duo, SD and MMC. It can be used as removable storage disks in enormous data exchange applications between PC and PC or PC and various consumer electronic appliances.
      The AU6368 reads digital content saved on memory card that user captured with the portable device such as notebook, digital camera,...
      10-23-2024, 03:26 AM
