Stripped iTunes...
  • stevo1210
    • Oct 2006
    • 4156
    Stripped iTunes...
    My Asus Eeepc 701 obviously doesn't have alot of storage room with Windows XP and a 4GB SSD, and I want to install iTunes. Now obviously I will install it to the SD card and not the internal SSD, but the damn thing still needs like 150MB in the internal SSD. So is there like a stripped down version of iTunes out there that works with my iPod touch?
    Thanks.
  • stevo1210
    • Oct 2006
    • 4156
    Re: Stripped iTunes...
    I tried a 3rd party "mini iTunes" and that didnt work with my iPod touch.
    • stevo1210
      • Oct 2006
      • 4156
      Problem solved... my brother found an older version of itunes in his HDD so that seems to work.
        • 31201
        Amarok audio player can load ipod's
        • NxB
          • Feb 2009
          • 1595
          Try sharepod. Itunes in all forms sucks.
            master hoarder
            • May 2008
            • 12175
            WinAmp should work too.
            Personally, I hate iTunes. It's bloated and doesn't have as many options as other players out there.
            • toastygoodness
              • Jul 2005
              • 813
              mediamonkey will work with ipod too...
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                yamipod
                sigpic
                (Insert witty quote here)
                • toastygoodness
                  • Jul 2005
                  • 813
                  http://www.i-funbox.com/
                  forgot you had an ipod touch, yamipod doesn't work with it, you need ifunbox
                  • weirdlookinguy
                    • Sep 2007
                    • 1638
                    Only iTunes will let you rearrange the icons on the home screen though, not sure if this is a big deal to you.
                    I hate Apple but... I broke down and bought a 32GB touch a few months back and I'll be damned if it isn't the coolest mobile device I have ever owned. I almost want to say it's the coolest piece of tech I own, but that would be my new Windows 7 rig I just built last September.
                      • 31201
                      gotta disagree, the coolest mobile-tech is my PSP with Go!Explore installed on it.
                      • Norrecito
                        iPod nano G3 - alternative soldering point for the white battery wire
                        by Norrecito
                        A friend of mine gave me an iPod nano G3 to see if I can fix it for him.
                        The device had a faulty battery and he tried to replace it but failed. In the process he managed to pull off the pads that corresponds to the white battery wire (marked with a red circle in the images)....from both sides of the PCB. Fortunetely he didn't damage anything else.
                        This is usually an easy fix HOWEVER, on the PCB, I see no traces coming from the VIA and after searching the internet, I've found no schematics nor boardview for this device. With the pads gone from both sides I seem...
                        09-07-2024, 03:54 AM
                      • Earwigg
                        Scematic/boardview request for iPod touch 7th gen
                        by Earwigg
                        Hello all,
                        perhaps I'm just too dense but i have not found any documentation on the ipod touch anywhere. i do alot of work on these (about 50/week) and would love docs if anyone has them.
                        thanks for looking.
                        09-04-2025, 12:49 PM
                      • A94M
                        Sony XBR-55X850C Stripped Screws
                        by A94M
                        I'm currently in the process of replacing the LED backlight strips and during the midsts of getting the outer bezels off, in order to take off the screen, I stripped a couple of the tiny screws. Does anyone have an idea of the type of screw/size so I'm able to replace them? I'm just wondering if it's a specific non-conductive metal or not... a bit hesitant on going to the local hobby lobby, matching them up size wise, turning the tv on and then having it explode because it was the wrong metal lol
                        I was able to extract the few stubborn screws using a Dremel, and making a notch for...
                        11-15-2020, 09:08 PM
                      • Guardian749926
                        Apple iPod Classic 30GB
                        by Guardian749926
                        Hi All,
                        I'm looking for the A1136 iPod classic schematics and Boardview.
                        It was water damaged but fixable. Any and all suggestions are welcome.
                        Thanks in Advance.
                        10-09-2022, 07:32 PM
                      • jaycee147
                        Gear4 houseparty ipod dock
                        by jaycee147
                        Hi all.. don't even know where to start to search for this MCU. No markings on it whatsoever. It is shorted and now removed. It comes out of a Gear4 houseparty ipod dock speaker that also has Fm Radio and Aux input. 12v supply but chip is on a 5v circuit. Photo of said chip attached....
                        09-10-2022, 04:41 AM
