Damaged mobo
  • Dawg
    • Jan 2010
    Damaged mobo
    Hi, I was wondering if any repairers have come accross this fault and successfully fixed it? Basically I removed an external drive during post and it caused the pc to re-boot and then hang pre post, no video. The only way to get it back on is to leave it unplugged for about 8 hrs, once its running it is ultra stable 24/7 but If I shut it down thats another 8 hrs with no pc. Ive updated the bios hoping it was just corrupted but this has made no diff, the other wiered thing is that 50% of the time when ive turned it back on I have to totally reconfig the Bios, this is a pain as its overclocked, a bit.....
    I guess I have spiked an ic somewere but I cant afford the trial and error replacement option, If someone supplies Bios chips and they dont cost the earth then I dont mind giving that a go. Does anyone else think this could be the likely candidate?
    The board is a P5K Premium WiFi Black Pearl.
    Many Thanks
    Alan
  • kaniki
    • 514
    Re: Damaged mobo
    usually if the bios is not remembering the settings and having to be redone, it is usually because of a compatibility issue with the processor (maybe overclocked but not the proper settings for voltage, etc.) or the CMOS battery is going dead (Usually a CR2032 button watch style battery)
    Does it only do this when it is overclocked or have you checked it with factory settings to what the parts are rated for?
    • Dawg
      • Jan 2010
      Re: Damaged mobo
      Thanks for the reply Kaniki, as I said the fault occured when I unplugged an external usb drive during post, it doesnt re-set the bios everytime but it does hang with no video and no post everytime. I have tried it with standard settings but that was just a shot in the dark, the components are rated at there overclocked spec.
      • XxMicroSoldering
        ASUS Rog Strix G17-712LV Laptop Liquid damaged
        by XxMicroSoldering
        Hello Guys
        I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
        10-17-2024, 10:45 AM
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • Tomylee
        Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
        by Tomylee
        I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
        It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
        I'm looking for help with the following:
        The exact identification or part number of the T5 component
        05-28-2025, 12:42 PM
      • Cerberuska
        Mobo MSI B550-A PRO password popup
        by Cerberuska
        Hello guys,
        I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
        BIOS I updated to last one.
        any suggestions?
        And same thing for two different 5600G, and yes, MoBo supposed to support it.
        Thank you...
        11-10-2024, 01:23 PM
      • mrsith
        Dell G3 17 3779 - no display after mobo replacement
        by mrsith
        Hi guys,
        I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
        Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
        04-30-2023, 05:11 AM
