Building new HTPC, CPU Advice?
  • tojoski
    • 5
    Alright guys, motherboard wise I pretty much have my mind made up either way I go, but I need help with the cpu choice..
    The new Core i3 530, at $125 or the Pentium e6500 at $95 ?
    http://www.newegg.com/Product/Produc...82E16819115222
    http://www.newegg.com/Product/Produc...6093&Tpk=e6500
    This machine will at times play back h.264 video, so either should do the trick, I'm just thinking the core i3 will be a little more future-proof.
    This is the board I picked for the i3 : ( all solid caps )
    http://www.newegg.com/Product/Produc...82E16813128421
  • Megawatt
    • 81
    • South Africa
    Re: Building new HTPC, CPU Advice?
    how bout the amd athlon 620 with a 785g ?
    • c_hegge
      • Sep 2009
      • 5219
      For a HTPC, I like the Pentium Dual core CPUs (not to be confused with Pentium D). They run very cool and so the CPU fan doesn't have to spin fast to keep it from overheating (even though the stock coolers are tiny). In a review i read about the newer core i__ CPUs, they would run a bit warm with the stock cooler. In other words, I would go for the Pentium E6500.
      • tojoski
        • 5
        My mind keeps going back and forth...
        I think (atleast for the moment) I'll go with the e6500 and a full atx motherboard.
        I'll use my old geforce 6600gt for graphics for the time being, and upgrade it one of these days if I decide to play games on the big screen.
        Does anyone know by chance the idle power usage of the e6500? I'm considering using it for my home server also.
        Joe
        • bgavin
          • Jan 2007
          • 1355
          Home theater does not require ballz out horsepower.
          You are better suited with a power-converative processor that generates minimal heat. This reduces cooling fan noise.
          Your choice of case is more important.
          The Antec Solo case is a great choice for quiet operation and excellent cooling.
          120mm fans at a slow RPM move sufficient air and are dead quiet.
          I use the Antec P182 case, which is the larger brother to the Solo.
          Both offer bungee disk mounting, or soft silicone mounts for the disk drives.
          This is an excellent noise reducer. Both cases have fiber panels for noise reduction.
          I use an E8400 Wolfdale, 3 GHz, 1333 FSB, and a 63w power draw.
          Cooling is a Scythe Zipang with bolt-through kit, and an Evercool 140mm fan at 1100 rpm. Silent running. The Zipang with bolt through kit is a huge pain in the ass, but does work. I use the Thermalright bolt kit.
          If you don't have adjustable case fans, you can reverse the Molex pin group in the fan connector, so it runs on the 5v lines. This drops the RPM way down and makes the case fan silent. They move enough air to exhaust the heat. This is another huge noise reducer.
          I use passive cooled video cards based on the nVidia 9500 series. Excellent performers, $50 USD price, and rock solid. I use a Rocket V cooler (10$) which is 2x70mm fans in a PCI slot. This blows on the video card passive sink and works perfectly. Rocket V is 2 speeds. It is cheap, and some last a long time while others fail young (sleeve bearings). They cool the southbridge nicely, too.
          I use Corsair power supplies. Modestly price, modular cabling, 120mm fans, good caps.
          • tojoski
            • 5
            This is the best full-atx case I could find, looks nice too:
            http://www.newegg.com/Product/Produc...82E16811112082
            with one of these psu's:
            http://www.newegg.com/Product/Produc...82E16817139008
            this mobo:
            http://www.newegg.com/Product/Produc...82E16813128414
            Have you ever tested the power draw from your entire system?
            I'm getting the xeon counterpart for your processor, the e3110 for my server.. and I'm hoping at idle it won't draw too much
            • linuxguru
              • Apr 2005
              • 1564
              Intel D945GCLF2 mini-ITX board with a dual-core Atom 330 processor is the best value at the moment for a low-power HTPC box.
              • BOSCHNJAK
                by BOSCHNJAK
                ABOUT ME INTRODUCTION FILE
                2
                024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                2022 BEV, PROJECT ?
                2021 BEV, PROJECT ?
                2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                12-28-2023, 02:09 PM
              • piernov
                NVidia bumpgate
                by piernov
                Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                May complete this post at a later date with more details.
                Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                03-27-2021, 10:34 AM
              • Borse2008
                Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                by Borse2008
                Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                • There’s
                07-15-2025, 04:55 AM
              • Green Probe
                Mosfet Advice
                by Green Probe
                Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
                05-22-2025, 10:49 AM
              • user234
                Gigabyte Eagle 3060 Ti - Boardview / Advice request please
                by user234
                Recently installed a new motherboard but during the process I seemed to have damaged my Gigabyte Eagle 3060 Ti card.
                My motherboard ROG STRIX B550-A is detecting an issue with the VGA (light ON)
                I have attached 2 photo's of my GPU board, one above and the other is what I believe to be the 5V - as you can see, this has visual damage so looks suspicious to me.
                If I replace this part what are the odds this will resolve the issue? - any additional information on where to source the parts would be much apricated too!
                This is...
                05-10-2025, 04:25 AM
