wd diag error message
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    i am just testing a wd hdd for installation wd2500aajs sata client supply
    the dlgdiag 5.04f make some error at end of extended test
    it pass quick test though
    it make sector relocation error 0226
    unable to correct the errors found
    warning command issued while DRQ set
    any idea bout this shit? rma?
    i am testing a second for client, same model and will advise too
    perhaps he is a masochist, wd die early and then he buys more wd?
  • i4004
    • Oct 2006
    • 2029
    Re: wd diag error message
    and what should he buy, maxtor?
    seagate 7200.11?
    meh...
    check the SMART to see if there are any reallocated sectors...if so, rma...if they accept that...heh
    • washu
      • Jul 2009
      • 310
      It means it found one or more bad sectors and cannot remap them to spares. Likely it has run out of spares which is a very bad sign if the drive is relatively new.
      RMA it.
      • acstech
        GrumpyModerator
        • Jul 2007
        • 1432
        I agree with i4004. Computer equipment any more is a crap shoot. Might as well buy WD as anything else.
        RMA time.
        A man convinced against his will is of the same opinion still.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          other drive did the same. these are brand new.
          • i4004
            • Oct 2006
            • 2029
            try windows version (perhaps that old dos version is a dud for these new drives)
            http://support.wdc.com/product/downl...&sid=3&lang=en
            as they say:
            http://support.wdc.com/techinfo/gene...rcodes.asp#v28
            "226 Sector Relocation Error Failure to relocate a sector during drive repair. The drive has to be replaced."
            oh yeah, also see what SMART says via programs such as everest, or speed fan, etc.
            if everything STILL points to reallocation error, rma...
            i wonder if my hdds would pass those dldiag tests..i never did them...hehe...
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              yeah i agree. maybe a software prob.
              usually i run full test on any new drive.
              • i4004
                • Oct 2006
                • 2029
                i do keep an eye on SMART, though.
                nothing reallocated on my hdds.
                SMART also has parameter "Reallocation Event Count" for which wiki says the following;
                "Count of remap operations. The raw value of this attribute shows the total number of attempts to transfer data from reallocated sectors to a spare area. Both successful & unsuccessful attempts are counted."
                also see "Current Pending Sector Count"
                "Number of "unstable" sectors (waiting to be remapped, because of read errors). If an unstable sector is subsequently written or read successfully, this value is decreased and the sector is not remapped. Read errors on a sector will not remap the sector (since it might be readable later); instead, the drive firmware remembers that the sector needs to be remapped, and remaps it the next time it's written."
                if dldiag was right, then you should see something there.
                • NxB
                  • Feb 2009
                  • 1595
                  Its out of sectors to remap to. You can try hdd regenerator, its on hirens or http://www.dposoft.net/. If the drive is new I'd replace it. I've done this to old customer drives that failed so I could use them.
                    • 31029
                    try emailing wd if you have the same fault on 2.
                    it could be a software bug, or it could be a known bad batch of drives.
                    • acstech
                      GrumpyModerator
                      • Jul 2007
                      • 1432
                      I've seen this lack of quality control spanning most computer components throughout the industry. It isn't just hard drives. People can say "oh I got a few of these and they worked," but that only means the ones they got worked. I've personally built the same system, with the same components 3x and got different results on each one.
                      The QC anymore is, for all intents and purposes, non-existant. They push to get the product out the door, problems or not. Most people just put up with it, problems or no. If it's completely DOA they send it back and get a replacement. Better to replace a few than be second one out the door on the latest thing.
                      So what are we left with? Building a computer any more is a crapshoot. You've got unstable motherboards, overpriced or shoddy PSU's, fans that die, capacitors that blow up, drives that get bad sectors, etc. Ever take a look inside a Dell? See the decent capacitors in there? That QC extends to other components too! Funny how they get the "good stuff" and we get the crap. That is, unless you want to pay more. Arguments can be made for building a PC, but it's getting pretty thin. Like I said, QC just isn't there for components you can buy. I've been in this for 12 years and I have seen quality take a nosedive. It used to be I could build a computer that would be more stable than anything the likes of Dell could produce, for about the same money. Now, with a 20% and growing failure rate, what's the point? I don't make money at it any more. I'm stuck with Chinese crap, unless I want to blow the budget.
                      So now it's either use server grade components, buy a Dell, or shoot the crap with Chinese sh*t.
                      Sorry to steal your thread Will. I'd say keep after 'em until they give you one that works. Hopefully they're not making you pay shipping.
                      • i4004
                        • Oct 2006
                        • 2029
                        good choices can still be made.
                        but otoh you can also have weird things like my friend recently had: his gb mobo started having sata controller issues...off to buy another mobo(this time asus) and it won't boot.
                        ok, he returns that one, he gets another one(anopther shop) msi, this time.
                        won't boot.
                        2 in a row?
                        then he removes the cpu and puts it back again, and mobo starts to work.
                        hihi....
                        crapshot indeed.
                        otoh, i got 2 biostar mobos and both work "out of the box".
                        • Toasty
                          • Jul 2007
                          • 4171
                          >>other drive did the same. these are brand new.<<
                          Check for BIOS updates. Sounds like a controller problem.
                          veritas odium parit
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            ok i tested them in my comp and the two new ones passed the extended test and even the user's original hdd which was going pingpingping in his comp passed too and was read fine.
                            so now i am looking at either mobo problem or its the shitty psu (opened it and it looked crap). will do more testing tomorrow.
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              well then no shit sherlock! (sorry, willa). bad psu= controller voltage issues. try another psu.
                              sigpic
                              (Insert witty quote here)
                              • Toasty
                                • Jul 2007
                                • 4171
                                Any progress Willa? Or has the office move taken over...??
                                veritas odium parit
                                • rumpumpel1
                                  T490 error message 2203 Skip acknowledgement of an error message
                                  by rumpumpel1
                                  I have a T490 that displays the error message “2203: System configuration is invalid” immediately after the Lenovo logo every time it boots up.
                                  This message must be acknowledged with 'Esc'. On the one hand, I cannot eliminate the problem, on the other hand, I have not observed any other restrictions.
                                  Is it possible to change the BIOS so that this message no longer has to be acknowledged?
                                  MTM 20N3S19L00
                                  system SN PF1X4JP8
                                  board SN L1HF171000X...
                                  01-19-2025, 03:32 PM
                                • tacetzz
                                  Pansonic CF-LX3EDKCS Error sending end of post message to ME, System HALT!
                                  by tacetzz
                                  I have 2 Pansonic CF-LX3EDKCS, One is Error ME Region,I have backed up to restore the fault but it still shows an error as tiltle
                                  Help me to create a bios to fix error. Thank you...
                                  06-21-2025, 12:19 PM
                                • Sus256
                                  HISENSE 65E7KQ PRO - no boot
                                  by Sus256
                                  Hi all!
                                  HISENSE 65E7KQ PRO
                                  RSAG7.820.13512 - chassis
                                  MT9618BAATAB - cpu
                                  RSAG7.820.12059 - power
                                  HD650Y3U77 - panel
                                  KLM8G1GETF - emmc
                                  Replaced emmc.
                                  Terminal log
                                  UART
                                  AC_ON
                                  E-B
                                  FDE enabled
                                  06-01-2025, 02:11 AM
                                • CapThatBrass
                                  CSE/Layout Project Error Message - FIT Tool
                                  by CapThatBrass
                                  Has anyone come across the attached error message whilst using CSME System Tools v16.0 r3.
                                  I've just loaded up an XML generated from the same application, and the error appears with no real clue as to how to fix it:
                                  Exception: Error occurred whilst trying to create container CseRegion. Reason Mismatch between CSE version and layout project version
                                  Layout Accepts: 16.0.x.y
                                  CseVersion: 16.1.25.2128
                                  Source: CsePlugin: CseRegion
                                  Source: CsePlugin
                                  Thanks in advance (hopefully someone knows....)...
                                  06-13-2023, 12:17 PM
                                • Superbee_dad
                                  Sharp 80” long short flash backlight error - Help
                                  by Superbee_dad
                                  Hello Sharp TV experts
                                  Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                  > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                  > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                  01-24-2025, 11:51 PM
