NAS boot issue
  • alindumitru46
    • Aug 2015
    • 255
    • Romania
    NAS boot issue
    I have an old NAS, Thecus N2310 with PowerPC 465 CPU @800 MHz
    There is a teardown https://www.youtube.com/watch?v=L3z3A9Tk8X4
    I have experienced frequent problems with system corruption, resulting in emergency and temporary repair and I thought to check the CR1220 battery, similar to computer motherboards, which was outside the parameters with a voltage of 2.5V.
    I have already replaced the battery, but I can't start the NAS to continue with OS6 installation or reinstall procedure.
    Although there are methods specific to the manufacturer to rewrite the firmware, I failed to do this and, similarly to computers, I think that there should be a method to force the writing of the firmware or the start of the writing sequence.
    Can you give me a solution to revive this NAS?
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: NAS boot issue
    Some NASs have software that resides on one (or more) of the drives. Firmware on the "motherboard" just loads this into the system's memory. (this isn't the case for all NASs as the FLASH complement is increasing and, with it, the amount of cruft that can be crammed into the FLASH image)
    For such a system, a defect in the FLASH contents (firmware) OR the image stored on the disk(s) leaves you with a non-functioning NAS.
    In some cases, the firmware will fallback to relying on a TFTP service (or comparable) to download its disk image from an external server. In those cases, it's just a matter of having all of the right services in place for the NAS to perform this task (often initiated by some "magic button sequence")
    • alindumitru46
      • Aug 2015
      • 255
      • Romania
      Re: NAS boot issue
      Ok.
      The firmware is stored on the Micron nand flash: https://techplayboy.com/10959/thecus...rage-review/4/
      There is a procedure to force write firmware:
      http://esupport.thecus.com/Knowledge...27-usb-upgrade
      But I think the process cannot start because I used multiple usb flash disks without success.
      And I keep thinking that maybe I can get him to start reading the USB flash somehow...
      LE:
      I verified with a backup hdd but is not initialised, does not spin at all. I also suspect that the USB flash disk is not detected because the boot procedure is not initialized.
      Anyway, I'm intrigued by the LAN led and power led continuous activity. I think that only trough LAN port I could force a write but I can't figure out how, if a device is not identified by the router.
      LE2:
      I took courage. I thought of connecting my NAS directly to the computer. I captured the activity with Netmonitor3 and I see that the NAS is identified. But I don't know how relevant the information is. What is certain is that it is detected and there is a chance to be accessed, to receive an order through a protocol accepted on etehrnet ...
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        Re: NAS boot issue
        Ok.
        You have to very carefully review the process that is prescribed. Little changes can cause it not to fail (e.g., having the network cable plugged in may change whether or not the process works; failing to hold down any magic buttons at the correct time; etc.)
        LE:
        The LEDs associated with the LAN may be driven entirely by hardware. I.e., they may simply reflect the signals detected on the network connector. Don't assume the processor is actually involved.
        You can use a network monitor to see if there really is any traffic originated by the NAS -- best done on a quiescent network, though.
        LE2:
        DHCP, BOOTP (simpler than DHCP so present in older devices), TFTP are the most common protocols relied upon for initializing "appliances" -- because they are low level and don't rely on a full stack to function correctly (less code to go wrong).
        You can watch for this sort of traffic on your network (start the analyzer BEFORE you power on the NAS so you can see EVERYTHING that it may be emitting).
        Once you have the firmware functional, you'll have to see how to coax the NAS into accepting it's "software".
        As that software will likely be stored on one (or more) disks, it's usually wise to image the disk after the NAS is working properly; this makes repeating the process a lot easier (just install the image on a new disk using another computer!)
        Damn near every NAS that I've owned has had a different procedure for reinitializing the software (after replacing drives). Taking notes helps to give you clues for the next NAS you end up annoyed with! :> Restoring images is a sort of universal way of avoiding the hassle.
        [This reminds me that I have to image the drive in my DVR while it is operational]
        • alindumitru46
          • Aug 2015
          • 255
          • Romania
          Re: NAS boot issue
          Thanks for this very valuable information . I will move on to experiment as soon as possible.
          Unfortunately I have 3 disks with previous images but none can start the NAS. It is not actually physically turned on.
          • Curious.George
            • Nov 2011
            • 2305
            • Unknown
            Re: NAS boot issue
            My advice? Do yourself a favor and repurpose an old PC as a NAS. There are several "free" packages that you can load on generic hardware and get these features (often MORE features than a "proprietary" NAS).
            [FreeNAS comes to mind. There are others.]
            Then, worry about how you can transfer the contents of those images to the NAS. (there are some tools available that purport to be able to read many NAS images -- for recovery, only!)
            The advantage that this approach has is you can replace the hardware at any time. And, add or upgrade disks - without relying on how/if some firm decided to support these actions.
            And, can possibly store information on the drives in a form that can directly be read without the support of the NAS software.
            Yeah, NAS appliances are "sexxy" in that they are smaller than real PCs. But, that comes with costs (that you are now experiencing).
            I've used "Shuttle" PC's, in the past, as 2drive NASs -- adding other drives externally via USB. You'll have to decide what your needs are and the extents you're willing to go to achieve them.
            (I.e., you could just buy a *new* NAS... <grin>)
            • alindumitru46
              • Aug 2015
              • 255
              • Romania
              Re: NAS boot issue
              I'm convinced of your advices. Fortunately, no recovery is needed
              But what displeases me about a new (another?!) computer is that I have to make additional investments in a silent source and a kit quiet enough and economical to be able to keep it on already too loaded UPS
              I also have an old EX475 that I would like functional again.
              • brethin
                • Dec 2008
                • 1907
                Re: NAS boot issue
                nothing wrong with a NAS if you know how to maintain them, I Have 42 hard drives for Buffalo NAS units with firmware I have restored over the years, it's just a matter of knowing what you have and how to fix it.
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  Re: NAS boot issue
                  Sorry, I just noticed your location. We think nothing of having "extra computers", here.
                  Unless you are really hammering on your NAS, you can usually opt for a less capable "PC" to host the software. I've used "diskless workstations" with external USB drives to expand storage. They (the workstations) are often fanless -- as are the external drives.
                  I just pulled two T610's out of my stash (I rescue these as there is little recycle value in a box that weighs less than a pound!) to use for a database server. With an external USB3 drive, the network will likely be the bottleneck.
                  The advantage is that you don't have to deal with whatever software the NAS vendor opted to think was appropriate for their product and can, instead, rely on more mainstream support.
                  [I have over 200T in my NAS/SAN fleet; probably 150 physical drives?]
                  [Note that you can also operate the NAS as a SAN with some of these FOSS packages]
                  • alindumitru46
                    • Aug 2015
                    • 255
                    • Romania
                    Re: NAS boot issue
                    Guys, if that's somehow part of your daily work, I'm just doing it as a hobby.
                    @brethin, I don't quite understand what you mean by "firmware restore". I know very well the firmware restoration procedures from Thecus and I tried both options:boot with an older hdd backup and rewrite with usb flash disk.
                    Maybe because my NAS is entry level... but maybe you enlighten me in case I didn't do the right thing
                    • Curious.George
                      • Nov 2011
                      • 2305
                      • Unknown
                      Re: NAS boot issue
                      It's not part of my "job" (I'm not an IT person). Rather, I have a sh*tload of stuff that I preserve as a consequence of designing hardware/software (for decades).
                      As a "normal person", I'd typically just be buying bigger disks for my "PC". But, why would I want to keep all that stuff on "my PC" when most of it is for legacy purposes (do you have your tax returns on your PC? Or, have you archived them, somewhere?)? And, once you get beyond a few TB, it's just not convenient to store stuff INSIDE a PC (usually, you need more spindles than the PC supports).
                      So, move the disk drive to a "headless PC"... a box that you interact with via a network interface/protocol. As such, you need a CPU, some RAM (for the code that the CPU will execute as well as "working memory"), a persistent place to store the software (on an internal disk/flash), a network interface(s) and one or more disk interfaces.
                      With the T610 approach (external disk used to store files), you can swap external disks to increase capacity while the "software" remains on the T610 (internal flash or laptop drive).
                      [I have "disk shelfs" -- 15 or 12 removable drives per shelf, usually 3 shelfs per storage device (NAS or SAN) -- that are driven by a generic processor box.]
                      • brethin
                        • Dec 2008
                        • 1907
                        Re: NAS boot issue
                        I can't really help you with this device, if it were a buffalo unit of any type I could sorry.
                        • ekozeko333
                          [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                          by ekozeko333
                          I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                          🔥 The Problem Started After Suspected ESD/PD Fault
                          I experienced a power issue or ESD event through a USB-C charger
                          After that, the NX20P5090 power switch was visibly burned and was replaced
                          Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                          🧠 What I’ve Done So Far
                          Flashed...
                          06-21-2025, 02:48 AM
                        • hinisa
                          Xiaomi router freezes at boot after re-capping
                          by hinisa
                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                          07-08-2023, 05:58 AM
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • zoltor
                          Canon G3430 has a lightning flash after the firmware
                          by zoltor
                          Good afternoon. The Canon G3430 is lit by lightning after the firmware, it does not respond to the buttons. I did not flash it, they brought it with traces of soldering, and all three chips. SPI - IC401 25Q128, IC402 25Q32, IC403 M24128. The SPI flash drives may have been confused in places. The QM8-0985 formatter. I've tried all the firmware available on the Internet, and the result is the same. I ask you to send dumps of chips, if someone has the same revision of the board, also tell me if the location of the SPI flash corresponds to the position numbers. Thank you very much in advance.
                          Yesterday, 12:40 AM
                        • abajor
                          Alienware Area-51 R2 Boot Loop issue.
                          by abajor
                          I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
                          It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
                          To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
                          Right now I'm trying to dig through the PDF schematics and Board...
                          03-08-2024, 10:08 PM
