recover data from micro sd soldering wires
  • dellxps15
    • Feb 2014
    • 1596
    • italy
    hi, dunno if this is the right thread place, but im wondering if someone had a problem with an sd by recognized after about 30 mins , but unable to recover data even after 1 hour..... on mobile phone it isnt recognized and phone ask for a password (it didnt had any kind of password set). i tried already all data recovery, but i think more i use the sd more it will get damaged. even after pc see the capacity, program lfor data recovery stay at 0% scan after 1 hour, so i left qnd quit the process.
    now im asking if any of you know how to solder wires on sd and what i need to connect to pc. ive seen some video, but or they are adapter u need to buy and are not cheap, or some arduino homemade reader, but cant find any schematic or good guide to look at.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: recover data from micro sd soldering wires
    onboard flash?
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3264
      • Singapore
      wikipedia has the pinout for all sizes and types of sd cards: https://en.wikipedia.org/wiki/SD_card#Transfer_modes
      however, it looks like the issue is that the card has failed and all the data is gone and corrupted. data recovery from failed flash mem devices is very difficult and most likely impossible because the data has drifted by one or a few bits due to voltage drift corrupting the data bit levels so u'll most likely end up with garbage data. thats why im still sticking to spinning rust for all my personal data archiving purposes.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        100%!!
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • dellxps15
          • Feb 2014
          • 1596
          • italy
          tnx for reply... i was talking about something like that :
          https://www.youtube.com/watch?v=jjB6wliyE_Y
          and looks like it will get almost all data on the damaged sd. ive seen also using arduino as reader, but dont have any schematic, tutorial or so to make it and give it a try.
            • 31142
            you could freeze the card and then dump it as a sector-dump with DD in Linux.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              yeah i'm wondering how he knows which points on the card on the right ones for data
              • dellxps15
                • Feb 2014
                • 1596
                • italy
                there is a site that has most of the sd card pinout
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  I hope you have the solder skills, a steady hand and a good microscope
                  • mon2
                    • 14509
                    Good soldering skills or you purchase one of these micro probe stations:
                    US $13.00 | Probe Data Recovery SD Memory Card Flyline PC3000FE Chip SSD Electronic Test Tool
                    https://a.aliexpress.com/_m0ZYUf7
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      that is pretty fucking cool
                      • ChaosLegionnaire
                        HC Overclocker
                        • Jul 2012
                        • 3264
                        • Singapore
                        wow that looks like some kind of a serious brain surgery lobotomy device!! funny how they ported medical instruments to fix electronics also. lmao!!
                        • Taurus12
                          Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                          by Taurus12
                          Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                          I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                          i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                          Any recommendation on what I have to do next? Thanks in advance
                          06-10-2025, 05:05 PM
                        • Azurain
                          Elitebook 840 G5 Bios Chip Soldering Question
                          by Azurain
                          I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                          Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                          04-14-2023, 06:58 PM
                        • dbuergi
                          DIY: Modified smart charger for all types of batteries
                          by dbuergi
                          sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
                          Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
                          My first work was to bring my Samsung watch battery back to life with was not recognized...
                          07-18-2025, 03:17 AM
                        • langbaobao
                          DIY 3D-Printer WSON8 Pogo Pin Adapter
                          by langbaobao
                          Hi.
                          I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
                          I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
                          01-08-2024, 05:58 PM
                        • ARKADII KAPLAN
                          boardview schematic for acer DAZAWMB18B0 motherboard.
                          by ARKADII KAPLAN
                          Hi there all, Merry Christmas and Happy New Year!
                          Looking for advice, Need to restore/fix the damaged Acer Aspire 514 -54 power circuit pathways.
                          I am not good at reading schematics and have difficulty finding the board viewer schematic or simple schematic for damaged parts, but I have all the tools and experience for micro-soldering. All I need to figure out is which ends (from-to) and trace wires to restore lines.
                          Hope the pictureS are clear enough to see the problem...
                          01-05-2025, 03:57 AM
