my dad had a cowerker that need help. she said it geve her an insert boot disk error. i got it home and time for specs:
cpu- ibm branded 486 dx2
cpu fan dead
RAM- did not check
vid- trident vlb card
i/o- vlb card
drives:
hd 1.2gb
4x cdrom
5.25/3.5 floppy combo
i had a brand new asus p2b-b at board that i got a a thrift store for 2 bux... so i mounted it with a pIII 550 with thermaltake orb cooler.
i looked at rhe psu... 235w... i removed the cover...
lets see
no pri. choke (jumper wire)
4 diodes
tiny silicon
finless tiny plates for heatsinks
no x/y caps (spot on board)
primary caps 220uf
tiny tranformers
so, i will need to find an at psu that is SAFE or a new power sritch to convert it to atx... tthe board will do either.
i added a case fan to the front, to make use of the 3 fan headers on the new board
i will have to go get a couple i/o cords... parallel was soldered to the i/o card. i think it has a USB header... if not, ill add a 4 port usb 2.0 card i happen to have.
since she uses dial-up, she will either get windows 2000 or xp home (i have a liscense off an hp case from a friend who used linux on it). xubuntu if she switched to dsl or i can get a modem working.
the mobo/cpu/io card/vid card/sound card will be kept as museum pieces for my room.
the hd may or may not work... i will see. at the least she will get a 13 or 6 gb hd.
also, i will upgrade the cd rom to 40x (dvd?) and give her a fresh floppy... and if i use one of the 2 aviable 3.5 bays (3rd rear bay removed to make room for slot-1 cpu) for the floppy, then i will add a second cd-rom drive.
dang, for free plus parts i have to buy, she is getting a deal.
am i doing the right thing?
cpu fan dead
RAM- did not check
i/o- vlb card
drives:
hd 1.2gb
4x cdrom
lets see
4 diodes
tiny silicon
primary caps 220uf
tiny tranformers
