Windows Vista OEM question
  • Maxxarcade
    • Jul 2006
    • 973
    I have Vista Ultimate x64 on my desktop, which I bought OEM.
    If I decide to buy Windows 7 in the full OEM version and replace Vista entirely, would I be able to use the old Vista disc and key to install to another computer, or is it locked to the current hardware? I've done it with XP, just had to call and get a new key. Not sure how it works with Vista though.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Windows Vista OEM question
    I'm sure the same policies apply with Vista.
    From my understanding when you register a CD key it stores your current hardware configuration on MSs servers as long as your hardware matches the same footprint (with the exception of minor changes like memory, HDD, etc) you can reinstall and reactivate as often as you want.
    If the hardware differential between what's on the server and what you have is beyond the limit then it won't reactivate and you have to call.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      A OEM key is bound to the mainboard, a retail key is not bound at all
      However you are allowed to change the mainboard on a computer using a OEM license incase the old one stops working...
      So when you call them to activate you have to tell them your old mainboard became damaged so you had to _replace_ it
