Garbled audio
  • toastygoodness
    • Jul 2005
    • 813
    Re: Garbled audio
    instead of a linux live (does slax work?) maybe try a winPE boot like bartpe or vistape or win7 pe (i think u can dl from microsoft)
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • i_am_patch
      Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
      by i_am_patch
      Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
      04-30-2024, 08:20 PM
    • silver60618
      Macbook M3 A2991 Speaker Audio Amplifier IC
      by silver60618
      Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
      I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
      09-26-2025, 12:25 PM
    • MOSSEP
      Monitor Audio RSW12 - Green light but no audio
      by MOSSEP
      Hi
      Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
      Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
      The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
      I have already tried replacing all of the...
      01-26-2025, 08:18 AM
