Garbled audio
  • pentium
    • Mar 2006
    • 2778
    Garbled audio
    My system has a Creative Audigy 2 ZS Platinum installed and since day one it's given out garbled sound. I reinstalled the drivers and that did nothing so I'm assuming it is a hardware issue and I don't think it is a noisy PSU issue either unless Corsair quality has taken a nose dive.
    Is there really much I can do to diagnose the card?
    Find Nedry!
    Check the Vending machines!!
  • washu
    • Jul 2009
    • 310
    Re: Garbled audio
    I would try in order:
    - Changing your output method. IE, use Waveout if using directsound and vice versa.
    - A different music player.
    - Try putting the card in a different PC, preferably with an Intel chipset.
    - Try a Linux live CD.
    - Try a different MAJOR version of windows. IE, if you are using Vista/7 use XP/2000 or vice versa.
    If it fails all that then it is probably toast. The Linux test will probably nail it, but the drivers for most newer creative cards are sketchy in Linux so the last test is to be 100%.
    Also, check your MB chipset. If you have a VIA one (or pretty much any non-intel chipset) there is a good chance you are screwed no matter what you do.
    • Wizard
      • Mar 2008
      • 2296
      Re: Garbled audio
      Pentium, is your mainboard VIA based?
      Cheers, Wizard
      • pentium
        • Mar 2006
        • 2778
        Re: Garbled audio
        1: I don't know how to do that
        2:It's not in a music player, everything sounds awful from midi playback to those sounds windows makes when you plug a piece of hardware in.
        3: No other system to test with unless I want to tear my room apart.
        4: Impossible. The Sapphire Radeon HD 3850 AGP is not really liked under any live boot distro of linux. I just get a blank screen and I'm not going to hassle with it.
        5: Are you implying I rip out the hard drive, put in another one and try that? No. Again, it's too much work.
        EDIT:
        Now it's completely garbled. Any sound output sounds like trash.
        Find Nedry!
        • Wizard
          • Mar 2008
          • 2296
          Re: Garbled audio
          Pentium, you have not answered the question about mainboard chipset.
          PC built into part of house? Seriously?
          Cheers, Wizard
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            Re: Garbled audio
            Unfortunately pentium, when you have a computer, specifically a custom built computer, you are going to have problems one way or another. And you're going to have to open it up to do some basic troubleshooting.
            >>And you're going to have to open it up to do some basic troubleshooting<<
            • kikkoman
              • Jul 2007
              • 691
              Re: Garbled audio
              unless you are seriously into gaming, use the kX drivers.
              they may be confusing a bit first but they're superior in every way (except EAX support).
              "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
              • pentium
                • Mar 2006
                • 2778
                Re: Garbled audio
                Ugh, I'm getting too old for this.
                I'm being 100% honest here but I literally gave it an evil look and call it a piece of crap and it's working again!
                Okay, so I guess there is something flaky going on here. I think I can start troubleshooting it from here.
                Find Nedry!
                • washu
                  • Jul 2009
                  • 310
                  Re: Garbled audio
                  Given that it started working presumably without any action on your part it sounds like a chipset issue. Creative cards are VERY picky about the MB chipset. VIAs are the worst but pretty much anything non-Intel can have problems like this with Creative cards. It is very likely that it will break again.
                  But as 370 said, you are going to need to open your box to troubleshoot it properly.
                  • pentium
                    • Mar 2006
                    • 2778
                    Re: Garbled audio
                    I'm slowly making a pattern here but it still feels a little erratic.
                    If I power the system off for a while and then power it back on, the garbling goes away until I reboot, at which point it returns. A shutdown followed by an immediate reboot does not clear the issue either. So it appears something has to discharge first before the sound works but what I do not understand is why I'm not gradually getting garbling while the system is on.
                    I'm almost quite tempted to open the case up and pull everything I don't need installed and then keep plugging stuff in until I get the garbling again.
                    Find Nedry!
                    • Wizard
                      • Mar 2008
                      • 2296
                      Re: Garbled audio
                      Um watch out for bad caps and certain chipsets. I do not build computers into a house except wirings/network. Computers do have to be broken down once a year or so to clean up and upgrades and for any repairs if something failed so need for ease of access. Computers in a closet or on a table or under is perfectly fine.
                      Cheers, Wizard
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Re: Garbled audio
                        mine did that a lot... the machine is not in use but when it is, i hope a linux fix i found cures it.
                        sigpic
                        (Insert witty quote here)
                        • pentium
                          • Mar 2006
                          • 2778
                          Re: Garbled audio
                          It's still flaky but it's cleaned up a lot now. I think that purging the drivers and doing a few other things (including reseating the card) cured it.
                          Find Nedry!
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3113
                            Re: Garbled audio
                            How hot does the inside of your case get?
                            If it was not in all the way, it may have been heating up and expanding, pushing it out of the slot....
                            maybe....
                            • pentium
                              • Mar 2006
                              • 2778
                              Re: Garbled audio
                              During the summer in my old case the inside ambient temp was hitting 45c but now in the fall and with a new and much more ventilated case I'm about 30c.
                              Find Nedry!
                              • pentium
                                • Mar 2006
                                • 2778
                                Re: Garbled audio
                                It came back with a vengeance.
                                I was in the case again inspecting why my Ageia card was detected by the system but not responding (turned out to be the fan actually fell apart and possibly cooked the card unless these things have a thermal safeguard and was disabling the chip) ) as well as plugging in a hard drive so I could move data off it and all the reboots after that resulted in trash audio with no improvement.
                                Okay, so I have replaced drivers, reseated the card and run the system with some (but not all) of my hardware unplugged and it is still more unreliable than...uh...Well I don't know but it's being unreliable.
                                I know the PSU isn't being noisy as it's a nice Corsair 450W unit and the motherboard is nicely populated with Rubycon, Sanyo, and Nichicon caps.
                                I don't know.
                                Find Nedry!
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  Re: Garbled audio
                                  Sounds like an IRQ conflict. Something sharing the IRQ with it?
                                  Change slot.
                                  BIOS update?
                                  What is the mobo?
                                  veritas odium parit
                                  • pentium
                                    • Mar 2006
                                    • 2778
                                    Re: Garbled audio
                                    If it was an IRQ conflict, wouldn't the system be very explicitly telling me so in the form of something like a lockup?
                                    I'm in the midst of a drive recovery right now so I'll go see if anything is sharing resources with the sound card once it is finished.
                                    The BIOS is up to date and I'm using the MSI 865PE Neo2-P motherboard. It's quite nice even though I had to forcefully reprogram the BIOS to accept two floppy drives.
                                    Find Nedry!
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      Re: Garbled audio
                                      >>MSI 865PE Neo2-P<<
                                      http://www.msi.com/index.php?func=pr...=&prod_no=150#
                                      ...and with that piece of info we now know it's an Intel chipset, not VIA. Answers several previous posters questions...
                                      >>wouldn't the system be very explicitly telling me <<
                                      Like the garbled audio??
                                      I had problems long ago with sound (Creative Audigy), a network card, and a serial port all deciding they wanted the same IRQ. The network card suffered from dropped connections in the office network. There never was a "conflict" showing. No "flag" or anything of that nature. The system just said that x-y-z were sharing the IRQ.
                                      I spent a lot of time chasing it down thru Windows until one day I needed to fix the fan on my video card. In the process I moved the network card down a slot so I could fit a slot cooler. After a few days, I noticed I hadn't had any problems from the network. Speed was good and it was always available. What the....? It dawned on me the only thing that had changed was the network card position. I moved it back as an experiment and right away had network problems. ah-HA! Investigation showed the IRQ of the network card changed when I moved it to the other slot.
                                      I didn't discover the fix. I accidentally fell into it. You take what you can get some days.
                                      Could the BIOS "forced reprogram" have screwed with something that is messing with the sound card? We've all seen BIOS updates to specifically address sound issues.
                                      Is it OC'd in any way?
                                      Chipset drivers update?
                                      Is onboard sound disabled in BIOS?
                                      Just some spitballing of ideas...
                                      Toast
                                      veritas odium parit
                                      • Solder Boy
                                        • Nov 2006
                                        • 178
                                        Re: Garbled audio
                                        Well here's an idea you might want to check out... check the caps on the sound card for lousy ESR.. that might also be a culprit
                                        www.bcrelectronics.ca
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • i_am_patch
                                          Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                                          by i_am_patch
                                          Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                                          04-30-2024, 08:20 PM
                                        • silver60618
                                          Macbook M3 A2991 Speaker Audio Amplifier IC
                                          by silver60618
                                          Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
                                          I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
                                          09-26-2025, 12:25 PM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light but no audio
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:18 AM
