Network Printers
  • stevo1210
    • Oct 2006
    • 4156
    Network Printers
    My friend called me this morning about her printer. I fixed her Compaq Presario V2417AP laptop recently and I didn't set up the printer for her (totally forgot about it).
    Anyway it's a network printer but I'm pretty much clueless to what the hell is going on in terms of setting it up. I believe the printer is a HP?... making a random guess here because all the computers and laptops at her place are HP/Compaqs.
    Anyway how do I set up a network printer?
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Network Printers
    do you mean one hooked to the network directly or one at a terminal on the network?
    if hooked to the terminal, then:
    windows:
    make sure the printer is set to shared at the terminal. then at each other terminal, browse then network to find the printer, then double click it , wjich will start the process. you will then select models or install drivers by selecting "have disk". follow the on screen instructions
    linux:
    add a printer. select network printer and then windows printer via SAMBA and then browse the network tree to find it. then go on to select your model. follow the on screen instructions.
    its a bit more difficult for ones hooked up directly, but its not too hard.
    first, look at the printer's settings. you need the ip address of it. should be in settings somewhere. write that down.
    2. if you are in windows (and linux), add a new printer.
    Windows: when you select the port, choose "new port"
    and from the drop down menu, select the ip setting (its some thing goofy but has ip in it).
    use the default port # (should be port 9100) and enter in the ip adress you copied
    then select model or select "have disk" to use the inf in the driver package. if you already installed drivers, it should be in the list
    for linux, select from the new printer page, network printer and if the printer shows up (as the ip adress you wrote down) then select that. if not, the select hp jet direct, then enter the ip adress.
    keep the port on port 9100. then go on to select your printer model.
    there you go!
    ps- fyi, hp has the best linux support of any printer company. brother is second, canon/epson are tied, and lexmarks are paperweights for then newer ones (older ones had drivers but were a pain to set up.)
    sigpic
    (Insert witty quote here)
    • stevo1210
      • Oct 2006
      • 4156
      One printer is a HP Laserjet 2840 and the other printer is a HP Laserjet 8100... I don't know how to set these up... they are connected directly to a dynalink access point. Please help me.
      Thanks.
      • kikkoman
        • Jul 2007
        • 691
        first thing you need to know is the IP address. how to find out?
        a) it has a default ip (hp document -see below- says it could be 192.0.0.192) or
        b) browse the windows network neighborhood or look in the AP web config (both unreliable) or
        c) print a self test or config page from the printer's menu.
        maybe the IP can be set in the printer's menu. works with my very old LJ4 but i think all the new HP lasers have a web frontend.
        once you're there, the rest *should* be easy.
        http://h20000.www2.hp.com/bizsupport...ctID=c01548316
        "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
        • stevo1210
          • Oct 2006
          • 4156
          I'm just wondering... but does the laptop have to have the same "workgroup" name as all the other PCs to see the printer? The printer is connected to a Dynalink router and the PCs are connected to that Dynalink router too.
          • re-atari
            Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
            by re-atari
            Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
            Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
            02-03-2025, 06:49 PM
          • Curious808
            Brother HL-2140 laser printer: printer error (solved)
            by Curious808
            SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
            Windows 10
            Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
            Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
            06-22-2023, 11:11 PM
          • howardc64
            Samsung UN55JU650DF network/streaming problem
            by howardc64
            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
            07-09-2025, 12:44 PM
          • tobeend
            Bypass mdm macbook m2 ventura
            by tobeend
            1. RESET MACOS WITH IPSW
            a. Power off MacBook, press and hold the power button to enter Recovery
            b. Open Disk Utility, remove Macintosh HD
            c. Reboot, connect to the network to Activate Mac.
            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
            e. Release the other keys, but keep holding the Power key for another 10 seconds
            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
            05-26-2023, 07:18 AM
          • davg
            Home network connection problem
            by davg
            I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
            03-06-2021, 07:13 AM
