A Colossal HDD Failure
    master hoarder
    • May 2008
    • 12175
    Here's a good example of one: Seagate 7200.11 series, 1.5 TB, model ST31500341AS
    It didn't look bad on the outside or anything like that (I put that note on the HDD after I opened it… so there's some foreshadowing for you .) But as soon as I plugged it in, it sounded absolutely horrible, making loud clicking and grinding noises. I thought it might be bad spindle motor at first. Curiosity got the better part of me, as usual, so I decided to open it. And this is what I found:
    And a high-res picture (link format to save on loading bandwidth)
    https://www.badcaps.net/forum/attach...1&d=1580607991
    Uh-oh… Goodbye precious data! Hello magic “pixie dust”.
    I should have known to expect this, though: while opening the HDD, I did notice some black “dust” started sticking to my fingers “out of nowhere”. As I started opening the HDD more, I saw more of that dust pour onto my carpet – and let me tell you, this crap is hard to get off from there. Had to vacuum my floor several times to get rid of the few spots where the dust fell. Also took dish detergent to wash the dust off the skin on my fingers, as it is very fine.
    Fortunately, I didn't loose any data, as this wasn't one of my HDDs. It's a failed HDD I got from work. Still not a big loss in terms of data, as the HDD contained old surveillance video footages that were backed up elsewhere (and at this point, not really needed either.) Moreover, I don't even have to low-level format the HDD now.
    It's interesting that this HDD still kept the platters spinning, despite the obviously failed head(s). Maybe I should cut a round piece of sand paper and glue it onto that top platter – table top bench grinder/sander! Fitting purpose, given the above images.
    (No really, I might actually do that ^ )
    Anyone else have extreme HDD failures like this to share?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: A Colossal HDD Failure
    LOL!! I love it!
    I had a 15k do that once.... it made a hell of a racket!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • piernov
      • Jan 2016
      • 4437
      • France
      Yep worst I've seen was a 15k that had dead motor driver IC, melted spindle motor coil, destroyed heads and all platters surface gone into dust. Was stress-tested for a day to make sure it works then a couple of months later it died randomly while idling.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8331
        Oh! That will buff out just fine!
        • Dan81
          SNES-powered
          • Oct 2013
          • 1866
          Screw BSY (that's a 7200.11 ya' got there, had a 1TB model to work with that had BSY), that thing is WAY worse.
          Main rig:
          Gigabyte B75M-D3H
          Core i5-3470 3.60GHz
          16GB DDR3-1600
          Samsung SH-224AB DVD-RW
          Delux MG760 case
          • BigTroll
            • Sep 2010
            • 1317
            • LAMBDA SOND
            I hate seagate drives, when you said colossal failure i figured it would be a YUGE drive like a QUANTUM BIGFOOT!
            My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              "Certified Repaired HDD"
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I've actually had good luck with their server level Barracuda and Cheetah Seagate drives over the years. Back in the day, they were far less failure-prone than any of the others on the same platform (higher-end SCSI). Quantum was my most hated....SCSI or IDE, bastards would always just die without warning. WD didn't make SCSI HDD's, atleast I never knew of any, but WD was my favoured drive for IDE/SATA systems...and that still holds true today.
                Team : 49813
                Join in!!
                Team Stats
                • R_J
                  • Jun 2012
                  • 9594
                  I have a similar model: ST31000340NS, Seagate, ES.2 1000Gbytes, It would not spin up, I check that there was drive to the motor, and it was ok. So I opened the drive and the bearing is seized solid.
                  • BigTroll
                    • Sep 2010
                    • 1317
                    • LAMBDA SOND
                    I don't have much experience with scsi except 50 pin drives in my macs and most from the factory were quantum and seemed to last along time however they put some piece of foam in the drives thats flaking apart and killing them now, at least thats the word in the 68k mac forums. I do have one 2gb seagate scsi in a mac that still going strong but is very noisy.
                    For ide/sata samsung drives were my favorite before they sold out to seagate, always seemed reliable. but yeah the 7200.11 and 7200.12 are garbage, I just replaced my 1tb seagate 7200.12s last month in my camera NVR, both had over 2000 bad sectors and 1 became unreadable by my bios. both were replaced wtih 1tb samsungs with 48k hours on both no reallocated sectors.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      Happy to say my 19GB Quantum Bigfoot is still functioning into 2020~
                      Follow the white rabbit.
                      • Hondaman
                        • Sep 2008
                        • 1089
                        I thought there were clock mechanisms (just like the $3.88 clocks you buy at Wal-Mart) that could be fitted to the center of one of these platters. Are they still available at craft and hobby stores?
                        This clock would stand out from the "typical" hard drive platter that was turned into a clock.
                        Edited to add:
                        ...some piece of foam in the drives thats flaking apart....
                        Don't many drives (consumer drives, at least) have a "recirculation filter" (piece of foam or other material) to filter the air inside them? Many pictures of disassembled hard drives are on the web. Just like an old foam seat cushion, these filters may be falling apart due to old age. (There is also another filter to allow air to escape when the drive heats up and air inside the drive expands.)
                        • BigTroll
                          • Sep 2010
                          • 1317
                          • LAMBDA SOND
                          Awesome! I have a 8.0 Bigfoot in a 95 rig since it fits right in with the 8.4gb limit.
                          • R_J
                            • Jun 2012
                            • 9594
                            The filter in this drive is not foam but more similar to a cloth fiber, it is located in the top left of the of the drive above the platter in picture #2
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              The new Samsung platter drives are Seagate, IIRC!
                              IIRC, for drives, except maybe optical drives, Samsung only does solid state drives now.
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              Arc A770 16 GB
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
                              • TechGeek
                                Computer Geek
                                • Jan 2015
                                • 2254
                                *snip*
                                And they suck just as bad.
                                Permanently Retired Systems:
                                Kooky and Kool Systems
                                sigpic
                                • BigTroll
                                  • Sep 2010
                                  • 1317
                                  • LAMBDA SOND
                                  Don't worry these are samsung drives made before seagate bought them out.They were made in 2009/2010.
                                  • ChaosLegionnaire
                                    HC Overclocker
                                    • Jul 2012
                                    • 3266
                                    • Singapore
                                    yupp always check the label, RJARRRPCGP. they are samsung labelled drives NOT "samsung by seagate" labelled.
                                    anyway, bigtroll, are those drives u have HD103SJ drives? i luv those cuz they are the fastest 1tb drives around. faster than even the 1tb wd cav blacks. great for running raid 0. i use them on my bittorrent rig to increase throughput and to avoid disk overloaded warning messages on my 200mbps fibre line.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      Oh I bet!
                                      At 15k RPM, those platters have a lot of momentum. Ain't no head going to stop them just like that. I imagine it looked similar to the one above, if not worse.
                                      Nice!
                                      Your low level format is now complete, sir!
                                      Oh, I have a wonky one like that too. Posted it a while back here... or rather the power-up sounds it made.
                                      https://www.badcaps.net/forum/showpo...1&postcount=50
                                      ^ In short, that HDD still works, but has a hard time calibrating after a power up, suggesting it will probably fail soon. Has lots of bad sectors and had a few ever since I found it some 15+ years ago. As such, I never used it much. Maybe 50 hours total in those 15+ years, if even that. I mostly keep it just because its big and cool-looking - makes folks appreciate storage technology a bit more today.
                                      Good catch! I didn't notice this until now.
                                      Probably explains the condition it's in.
                                      Of course, it could also be that after it was refurbished/repaired, it was mishandled with shipping. I guess we will never truly know.
                                      Same - particularly with the Barracuda ATA IV/V and 7200.7 series. Some claim the 7200.9 are also very reliable, but I'm on the edge with that statement. The 7200.10 and later certainly weren't, though.
                                      As for WD... appears their HDDs are good as long as you don't power-cycle them too much (whereas Seagate appears to be the other way around.) I'm I hard "power-cycler" with my personal PCs, so I've had OK luck with Seagate HDDs so far and more or less OK luck with WD. Had a 80 GB WD fail a few weeks ago. No bad sectors, but started having a hard time starting up for about a week. Then it failed. I suppose that was a good enough warning, though. IME, WD HDDs usually don't give much warning when they are about to fail, whereas Seagate usually do (typically high bad sector count.)
                                      You sure it's not the heads stuck to the disk? Older Maxtor HDDs were notorious for this. I've also seen it happen to a 2.5" WD Blue (250 GB, IIRC.) When it comes to heads sticking to platters, that's where Hitachi shines, as they use those head ramps. Toshiba does too, IIRC... but that's all they got going for them. Hitachi, on the other hand, had/have some pretty decently reliable HDDs.
                                      One of the few left, probably.
                                      That's what I have in my "main" PC right now: a Samsung Spinpoint SP0802N. I believe that's also before Seagate acquired them, as it's an 80 GB IDE HDD. And even if it is a Seagate HDD, it's from around the same era as the 7200.7 and 7200.9 drives, so it should still be OK.
                                      • BigTroll
                                        • Sep 2010
                                        • 1317
                                        • LAMBDA SOND
                                        Just checked and YES they are both HD103SJ drives! One is up to 49000 hours now both show no reallocated sectors, both run 24/7 running as NVR for my cameras. I also know the older samsung drives said made in korea which no seagate drives were ever made in korea to my knowledge.
                                        I thought about using them in raid, but the computer is a ThinkCentre M78 socket FM2 lenovo and I havent heard good things about AMD raid so I never bothered.
                                        • npielawski
                                          MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                          by npielawski
                                          I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                          I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                          Today, 01:53 AM
                                        • RetroComputingGrotto
                                          IBM LTO 7 Tape Drive - Dust Sensors??
                                          by RetroComputingGrotto
                                          I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                                          I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                                          09-19-2024, 01:54 AM
                                        • puccovelli
                                          Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
                                          by puccovelli
                                          Hi all, I hope this is the right place to post.
                                          I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
                                          I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
                                          1] Could someone confirm what the component that has blow actually is (and where I could get another from).
                                          2] Whether this component is likely to cause the RAM failure issue, and if replacing...
                                          10-11-2025, 06:30 AM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          Replaced emmc.
                                          Terminal log
                                          UART
                                          AC_ON
                                          E-B
                                          FDE enabled
                                          06-01-2025, 02:11 AM
                                        • ctroxtell
                                          Carrier HK50AA063 display controller common failure help
                                          by ctroxtell
                                          I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                                          02-05-2025, 05:31 PM
