Hard To Find Matshita Firmware
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    I need some help here. This CDRW/DVD ROM drive is in a Dell C640 Laptop. Here is what happened to it. I didn't have it pushed all the way in and locked into my Lappy. As a result it just can't read disks now. I don't remember if it is just CD's or DVD's that it fails on or if it can't read anythig at all. It still reports what it is to the Lappy as follows: Matshita CDRW/DVD UJDA740 in windows Xp system. I was thinking that I may have screwed up its Firmware. Now I can't find the original firmware or and update for same anywhere. Does anyone here know where I can find something? Here is what it says on the drives lable. First it says Panisonic. However the next stuff is as follows Matshita
    UJDA740 DL5-A
    HW 1.01 FW 1.03
    Mark Twain
    John Paul Jones
    Rod Serling
  • NxB
    • Feb 2009
    • 1595
    Re: Hard To Find Matshita Firmware
    http://www.opendrivers.com/driver/21...-download.html
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      Thanks NxB! I got it.Now its time to use it. Got the firmware from Dell but it wouldn't refreash my firmware because it already flashed to the same version as the Dell update package.
      Mark Twain
      John Paul Jones
      Rod Serling
      • NxB
        • Feb 2009
        • 1595
        Some of the flashers have command line switches to force update.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          i doubt the firmware is the issue.
          btw all panasonic/matsushita drives i have seen id as matshita.
          must be a limit to name length.
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            NxB what would that command line switch be? I have two CDRW/DVD-ROM drives for this thing. The other is a HL Data Storage GCC-4241N, and its sick too. The HL reads DVD's just fine but has real problems with many CD's. I did find the firmware update for the HL and it reflashed just fine, It just may be alive again but I was too beat to mess with it anymore last night. The Matshita did everything well until I did my stupid trick of not having it plugged in all the way.
            Mark Twain
            John Paul Jones
            Rod Serling
            • slavetothesound
              HP ProDesk 600 G6 Mini BIOS unlocked - now EC can't find valid firmware
              by slavetothesound
              I Used a T48 and RCUnlocker to remove password from the BIOS on a previously fully functional HP ProDesk 600 G6 Mini. Everything went very smoothly and I was able to boot the machine and install an OS. I then unplugged the machine and put it on the shelf for a week.
              Now when I boot the machine, it does not POST. It plays 5.2 beep codes which are interpreted as:
              I read the firmware with the T48 and it is different than what I flashed to it, so I flashed the unlocked firmware that I had saved. No change. I could use some advice on next steps to take.
              04-12-2024, 10:05 AM
            • Coldblackice
              GoXLR-Mini.Possible to extract this firmware? Or find its datasheet?
              by Coldblackice
              I'm trying to extract firmware from a GoXLR-Mini
              https://www.tc-helicon.com/product.html?modelCode=P0DI7
              I know it's not ideal, but I'm trying to extract the 64MB firmware without removing the chip. I've done this before, but I realize it's a case-by-case thing. Unfortunately, it seems this board's layout results in it getting powered by my SPI tool (Buspirate), failing extraction.
              I believe the issue is the flash chip's HOLD pin unable to get pulled high, as the current for that pin dissipates elsewhere in the circuit. When I try to pull the HOLD pin...
              02-25-2022, 06:27 AM
            • federalhouse
              **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
              by federalhouse
              I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
              **Background:**
              I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
              **What I've Tried So Far:**
              1. I accessed
              08-01-2024, 07:03 PM
            • gurj1979
              Ubiquiti firmware help. US-8-150W POE
              by gurj1979
              Hi guys.
              I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
              Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
              So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
              Got New chip and writes good.
              THE PROBLEM...
              It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
              Does anyone have a Good Firmware I can have?...
              07-22-2024, 05:13 PM
            • Slapito
              Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
              by Slapito
              I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
              Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
              I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
              I already downloaded the BIOS update file from msi official...
              Today, 02:00 AM
