Computer freezing up.
  • mandrakeman46
    • Jul 2009
    I don't know if this is the right forum section to post this question, since I am new here, but here it is.
    I have desktop with an ASUS P5DVC-MX ver. 2 motherboard, with an Intel Pentium D cpu, with 2gb's of RAM and a 250 GB hard dive. The problem that I am having, is that my computer is freezing up every so often! Especially when I turn off my computer and restart it! It will freeze up at least 3-4 times, before finally coming on. Then, when I am using it, it will unexpectingly freeze up on me, without any warning! Its very frustrating! Especially when I am doing something on it and then boom, it freezes up! So, I have to restart it again! Whats also frustrating, is that I had just purchased this computer about 2 years ago, freshly built to my specs, and now this! What is also peculiar, is that when I do start my computer, after it has been off for a while, the power fan, will make a funny humming noise for a while, then the computer will freeze up several times. After about 2-4 tries at starting it, the humming noise will go away, and then the computer will stay on, before freezing up again a while later! See how frustrating this is! Any suggestions would be appreciated! Thanks.
  • stevo1210
    • Oct 2006
    • 4156
    Re: Computer freezing up.
    Do a memory test or change the RAM, I have seen similar symptoms happen to an Asus P5B-E and RAM solved the issue. Otherwise check the power supply and see if that's OK. What brand power supply are you using?
    You also might want to check if your CPU temperature is ok or not, or if the cpu fan and heatsink is still clean?
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
    • mandrakeman46
      • Jul 2009
      Thanks for replying to my post stevo1210. I use an X power supply ps-400 watt power supply. I also use a program on my motherboard CD that monitors my computer specs, including fan speed, cpu temp. motherboard temp and so forth. I also clean out my computer at least once every two weeks, by blowing out the dust. BTW, how do I do a memory test? I know a little about computers, but I am not a computer specialist by no means. Also, just curious, what is the difference between your ASUS P5K-E WIFI and my PVDC-MX?
      • KeriJane
        Mac Enthusiast
        • Sep 2008
        • 681
        Hi Mandrakeman
        Welcome to the Forum!
        Your symptoms are consistent with Bad capacitors on the motherboard, in the Power Supply or even on a videocard but of course could be something else.
        Bad or failing capacitors will often fail more when cold but settle down when warmed up a bit. A capacitor problem usually manifests after a couple of years of use and will cause voltage fluctuations and excessive "Ripple" which is kinda like really fast voltage fluctuations. This will cause unstable operation, hard to boot conditions and possibly even "funny humming noises".
        Fortunately, bad capacitors are usually easy to spot. The top of capacitors usually have a "X", "K" or "Y" shape stamped into them. This stamp is a vent that allows pressure from a failed cap to vent without an explosion.
        If any caps are bulged outward at the vent or if any gunk has leaked out at the vent or at the bottom, the cap has failed and must be replaced to prevent further damage.
        Caps to inspect are on the motherboard, the videocard and inside the Power Supply. Primarily, you're interested in any with a vent.
        An "X Power supply" is not a common brand. Is that the name label? This is important because the PSU is likely to be your culprit.
        Good Luck,
        Keri
        PS. The cap on the right has a bulged "T" shaped vent... see picture. This is what you might want to look for.
        The More You Learn The Less You Know!
        • 370forlife
          Large Marge
          • Aug 2008
          • 3113
          Never heard of Xpower.
          Thats not good. Try using a more reputable psu (delta, seasonic, acbel, silverstone, new antec, corsair...)
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            xpower? sounds like a gutless wonder.
            sigpic
            (Insert witty quote here)
            • Newbie2
              • Sep 2005
              • 885
              I would immediately think the power supply is the culprit behind your odd freezing up problems if it is a cheap generic unit. "X power supply ps400" definitely sounds like a generic power supply to me.
              Get a better power supply from brands such as Antec, Seasonic, Enermax, etc. (370forlife mentioned the others), that might just fix your problems.
              My gaming PC:
              AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
              ASUS M4A77TD AMD 770 AM3 Motherboard
              PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
              G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
              TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
              WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
              ASUS Xonar DG 5.1 Channel PCI sound card
              Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
              Antec Three Hundred Mid-Tower Case
              Microsoft Windows 10 Pro 64-bit
              Microsoft Windows 7 Ultimate SP1 64-bit
              • 370forlife
                Large Marge
                • Aug 2008
                • 3113
                Damn I forgot enermax
                • golemmaster
                  • Jul 2009
                  • 100
                  We need more info. Many things (and combinations of things) can cause similar symptoms. Break down the specs and brands of core parts for us (MB, Video Card,...) Pics are nice if you can.
                  If the computer freezes but the video stays on the screen without corruption, frozen mouse pointer, keyboard unresponsive (tap numlock and watch status light):
                  I suggest check/swap the PS and examine the video card for bad caps and seized/noisey fan if there is one.
                  Make sure your video card is not choked for air. Too often I see other cards right up against the video card fan inlet or heatsink. Give it some breathing room.
                  Of course check for bad caps all around!
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    iirc x power is a gutless wonder.post a pic with the cover off.edit.
                    x power is a pile of shit.
                    http://www.atxpowersupplies.com/powm...y-550-watt.htm
                    • KeriJane
                      Mac Enthusiast
                      • Sep 2008
                      • 681
                      Oh!
                      It's a POWmax.
                      Powmax has a well-deserved very, very poor reputation. I keep a brand new "400w" Powmax under my sofa as a joke.
                      My best advice is to immediately unplug it from the wall and go ANYWHERE and get absolutely ANYTHING else. Even crummy ol' Dynex from Best Buy is far better.
                      But it's probably best to stick with the above mentioned reputable brands.
                      Good Luck,
                      Keri
                      • bgavin
                        • Jan 2007
                        • 1355
                        The Sparkle ATX-350 from Newegg at $34 is an inexpensive PSU that works well. I have dozens installed in my client machines and zero problems.
                        OP, clean power is your first requirement.
                        Obviously you have a crappy PSU. Replace it before it kills your hardware.
                        After you have clean power, you are looking for memory problems.
                        Memtest86+ across 24 hours, error free, will vindicate your memory.
                        Any errors at all... is not acceptable. BSOD 0x50, other problems.
                        One of my new clients brought in a machine that was random BSOD and freezing. It didn't fail Memtest until it was past 15 hours of run time. It is important you run hell out of Memtest for 24 hours.
                        Prime95 is another program that will crap out with memory problems.
                        I use Prime95 as a final test to verify memory integrity.
                        Video hardware will cause freezing. Onboard GMAC, etc has to be disabled in CMOS so you can use a separate card. Swap cards if you suspect yours.
                        Most freezing problems I see are hardware related. Very few in the OS.
                        • shouri
                          Dell latitude e5490 auto restart
                          by shouri
                          Hi guys, can someone help me?
                          I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                          Board model is dm70 la-f401p rev:1.0 2017-09-20.
                          At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                          After a few days test, is seems ok.
                          Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                          12-10-2024, 09:27 PM
                        • fulepost@outlook.com
                          Samsung "QE" series QE55Q70RATXXC Intermittant restart in "home mode".
                          by fulepost@outlook.com
                          Dear all.
                          I'm a less knowledgable member who would appreciate some guidence.
                          I have a Samsung QE55Q70RATXXC that works perfectly in "shop mode" but in home mode it restarts, Intermittantly.
                          With intermittant I mean the TV can work perfectly for a week and suddenly start to restart. Before the restart it may reach different stages. Sometimes it restarts when the "QLED" start screen shows up and some thimes it restarts after hours, and everything in between.
                          When the restart occurs, the screen blacks out leaving a light area alomng the edges fading...
                          11-09-2025, 07:10 AM
                        • Simplebeans
                          MacBook Pro A2338 keeps restarting when attempting to install macOS
                          by Simplebeans
                          I have just got in a MacBook Pro A2338 which was initially displaying the Apple logo followed by an explanation mark in a circle as described here:- https://support.apple.com/en-gb/102164.
                          After some error messages attempting to revive and restore the machine via DFU mode i have finally got the machine revived however now the issue seems to be when attempting to install macOS Sequoia via a bootable USB installer or via macOS recovery the machine just keeps freezing and restarting before the installation is complete, usually the installation has just started or is mid way trough before...
                          08-10-2025, 11:04 AM
                        • CornholioGSM
                          Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Battery
                          by CornholioGSM
                          I have here one interesting problem.
                          Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
                          I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
                          Quickly i am able to see battery information...batt is detected normally in os with power cycles hours...
                          06-25-2024, 12:27 PM
                        • FShahid
                          Dell Inspiron 7520 (Intel/AMD) LA-8241P Freezing Issue
                          by FShahid
                          Hi I have Dell 7520 which has i7-3632QM as well as AMD 7730M Discrete Switchable GPU.
                          This is BACO Switchable meaning the AMD GPU can only "render" and cannot work as alone as it depends on iGPU for output.
                          Attached is the datasheet for LA-8241P which shares common with Inspiron 5520 and Vostro 3560. Link to Schematics: https://cdn.badcaps-static.com/pdfs/...a856347d78.pdf
                          The laptop has worked flawlessly for last 9 years, with CPU temps never exceeding 90*C and GPU barely reaching 80*C on gaming/full load.
                          Since...
                          04-26-2022, 04:41 PM
