A good free anti virus?
  • Phaihn
    • Jan 2009
    • 842
    Can you guys sugest a good free anti virus?
    Other wise ill just stick to avg free. it seems to work good for me and its for the HP i gave to my mom and dad.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
  • shadow
    • Feb 2007
    • 732
    Re: A good free anti virus?
    I currently use Comodo Internet Security. It is free and I am having success with it. The firewall is excellent and the antivirus is decent. The main complaint about it is that it is over protective. Expect lots of popups coming up when you first installed it. The mass popups come from the fact that it also monitors changes to the registry, COM interfaces and the like.
    Therefore if a program wants to edit the registry, it will popup asking you to allow or disallow the change. This is no problem for me but it could be for some. Perhaps these extra protections can be made more lax or simply disabled so you will have less popups.
    Once you get the fist flurry of popups sorted out when you first install, popups generally only come when you install an application (where you can choose the option 'treat this application as an installer/updater' and you wont get subsequent popups).
    Another free antivirus that I have read is very good in Avira AntiVir. I do not have experience with it but many seem to think that it is great.
    • NxB
      • Feb 2009
      • 1595
      +1 on each of those. Avira has a higher detection rate but comodo gives you a firewall and other monitoring tools for more control.
      Avira pops up an advert when you update. You can disable it by killing the exe that does it.
      • Harvey
        • Apr 2007
        • 264
        I've used Avast free antivirus for the last 4 years or so, and have installed it on various friends systems - it works like a charm.
        • stevo1210
          • Oct 2006
          • 4156
          I use AVG free edition anti virus, it's pretty good in my opinion.
          • acstech
            GrumpyModerator
            • Jul 2007
            • 1432
            I second the AVG free. It seems to work well.
            A man convinced against his will is of the same opinion still.
            • m0sf3t
              • Jul 2009
              From information gleaned on another forum from those with knowledge of such things, use Avast.
              AVG and Comodo security are reputed to be crap.
              • acstech
                GrumpyModerator
                • Jul 2007
                • 1432
                I have never, once, seen a virus infected computer running AVG. Not once. Hasn't happened. I can't say that for other free alternatives. AVG has cleaned viruses that others, such as Norton, and other free alternatives, have left behind. I've been in the computer business for years BTW.
                AVG may have a larger memory footprint than some of the others, but it works well enough to offset this IMHO.
                • m0sf3t
                  • Jul 2009
                  I too used AVG in the past.
                  Then upon advice received, I uninstalled it and installed Avast.
                  Upon initial scan, Avast picked up loads of stuff that AVG had failed to pick up on.
                  • acstech
                    GrumpyModerator
                    • Jul 2007
                    • 1432
                    Funny, mine worked the other way.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      avg bad (porky and bloated), comodo better (used to use it), linux best!.
                      if windows is your vice, then id say comodo hands down. better than mccafe and norton (what isnt, then again)
                      sigpic
                      (Insert witty quote here)
                      • NxB
                        • Feb 2009
                        • 1595
                        Avast is bloated. AVG is a bit bloated but still manageable. End users tend to get viruses no matter what you put on. If you want to be "in the know" read www.av-comparatives.org and pick for yourself.
                        In the end the best AV is YOU.
                        • KeriJane
                          Mac Enthusiast
                          • Sep 2008
                          • 681
                          The best AV really is Y O U.
                          I used PCs for years without AV with no ill effects all the while fixing a TON of virus-infected systems for other people.
                          The best way to avoid virus:
                          1- Be really careful about opening email. Turn off HTML and never open an attachment unless you know exactly who sent it and why.
                          2- Don't be a Sucker! Most of the stuff people try to get for free on the Internet is just loaded with viruses and malware. This includes "Work From Home" sites.
                          3- Don't be a Dirty Old Man! Easy for me to say, but the most virus-plagued computers I've ever seen had some really gross stuff in the Temporary Internet Files folder. (I first came across it by trying to retrieve family pictures for someone.... ewww.)
                          I eventually developed a rule of thumb: number of viruses is proportional to number of dirty pictures viewed. The last (now deceased) D.O.M. system I worked on had well over 600 threats found before I quit the scan and re-installed.
                          4- Re-install Windows occasionally. Actually, I did this a lot to clean up errors caused by programs and uninstall routines and especially when changing hardware. It also gets rid of any malware.
                          I got to be really good pals with M$'s phone activation people though. (they hate me )
                          Personally, I like AVG. It's not perfect, but pretty good and no hassles.
                          Have Fun,
                          Macs (and Linux) get VERY FEW Viruses
                          Keri
                          The More You Learn The Less You Know!
                          • everell
                            • Jan 2009
                            • 1514
                            Can't resist the temptation!!!
                            When my IT man at work introduced me to Linux, I asked him what kind of antivirus it would need. He just laughed. I didn't understand what was so funny. He said Linux doesn't need antivirus!
                            So all you windows users ..... enjoy your sick computers.....
                            Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                            • KeriJane
                              Mac Enthusiast
                              • Sep 2008
                              • 681
                              LOL, everell
                              Maybe we should recommend Linux as a "Good Free AV"?
                              I'll stick with the moderately-priced "Leopard AV" that runs exclusively on reasonably priced (Cheap, even) Apple Computer Corporation Hardware.
                              Have Fun,
                              "Achoo!"
                              Keri
                              (Ducks)
                              • NxB
                                • Feb 2009
                                • 1595
                                Clam-AV works on linux.
                                NO NO NO
                                Audit your PC instead. Download autoruns and process explorer from SysInternals and LEARN what is supposed to be running on your pc. If you have something new look it up! If you kill something and it comes back, its probably a virus. Strangely named unsigned executable? Probably a virus!
                                  master hoarder
                                  • May 2008
                                  • 12164
                                  Sounds funny but it's true. Same applies to warez/serials/Limewire downloads.
                                  I liked AVG Free up to (and including) version 7.5, but after that (version 8 and later) it became too heavy on resourses for me. With 100MB of ram allocated for AVG Free and me having 512MB total, it does really slow down my system. Although I must say, it really is good with finding viruses. Nothing like Norton.
                                  I've also heard that Avira AntiVir Free is pretty good and lighter on resources. It's been nominated as CNet's Editor's Choice. I might give it a try actually. As for Avast, I like that it has the ability to do a boot scan but that's about it.
                                  Of course I agree that the best anti-virus really is you.
                                  • Phaihn
                                    • Jan 2009
                                    • 842
                                    AVG seems to work good for me. With 1 and half gigs of ram its got lots to work with.
                                    My Computer.
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      simple solution:
                                      use linux. i prefer the ubuntu version. it will do anything windows can without the bloat and jacked up prices.
                                      sigpic
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3112
                                        I use symantec corporate.
                                        Ya ya ya symantec is norton, but its not "norton" its completely different, and I always use it to clean up people's computers with avast and AVG installed, AVG and avast really only gets most of the virus, but leaves smaller spybots and stuff behind.
                                        Symantec corporate with malwarebytes and superantispyware. Very potent combo.
                                        • irepair559
                                          Ps4 1215a hdmi diode readings good everything good but no pic??
                                          by irepair559
                                          PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
                                          01-05-2023, 12:32 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • the_rem
                                          Unknown transformer : how to find a good replacement part ?
                                          by the_rem
                                          Hello guys,
                                          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                          04-23-2025, 01:48 AM
                                        • mon2
                                          Hunting down a virus in an office
                                          by mon2
                                          Hi. We have an office client who has been contacted by the local internet provider that one of the office Windows PCs is infected with a virus. The report has been confirmed. Apparently through a remote outside trigger, this virus is performing brute force attacks around the world from this local IP address at varying times. Aside from low level formatting each PC, what is the recommended approach for this case? Running F-prot (suggested by the internet supplier) has come up empty. We are planning to run hijack this. At this time, we do not know which PC is creating this issue. Internet provider...
                                          01-09-2025, 09:42 PM
                                        • cook
                                          Good brands of run capacitor for house heat hump
                                          by cook
                                          Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
                                          Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
                                          09-13-2024, 12:53 PM
