ThinkPad T400 fan in a 14.1in T61 widescreen?
  • Digi
    • Apr 2019
    • 12
    So, my cheap find has an issue with the fan being rattly, and as a result when I removed the heatsink and fan assembly, the glue and foil has perished from the fan and fins on the heatsink. At the moment I did buy a replacement fan but upon fitting, or trying to, it wasn't even a match.
    Now I'm figuring out whether a T400 fan is compatible with my 14.1in T61 Intel-only widescreen, as all I'm looking for is a replaced fan and a working unit again.
    I'd appreciate any input on this before I gallivant eBay and the like.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: ThinkPad T400 fan in a 14.1in T61 widescreen?
    Why not just buy the correct fan ? https://www.ebay.co.uk/itm/IBM-THINK...5/182038366582
    • Digi
      • Apr 2019
      • 12
      Originally posted by diif
      I'll bear this listing in mind, I appreciate it.
      But it was a question out of curiosity. My only worry on buying that one will have the same issues with the one I had last, with the pits for the metal copper tabs that surrounds the fan not lining up correctly,
        • 31199
        did you strip the fan?
        you may be able to replace the bearings.
        • Digi
          • Apr 2019
          • 12
          I thought about that, but I found a candidate to replace the entire assembly and will keep the heatsink and replacement fan for another unit that may also have issues on hand.
          I appreciate all suggestions!
            • 21626
            You can pull up the metal tabs on the housing and remove the metal plate,lift the fan off the shaft.Put a drop of sewing machine oil onto the shaft and put it back together, use some new aluminium heat resistant foil tape .
            • Digi
              • Apr 2019
              • 12
              Any recommendations for the tape?
              • brethin
                • Dec 2008
                • 1907
                the tape is just to keep the dust out, use anything you want.
                • Digi
                  • Apr 2019
                  • 12
                  Update on this: The replacement blades on the other fan fit just fine with the original, and since the unit has been repasted with the heatsink reinstalled it's been perfectly passive at 45c with the MX-2 paste I used.
                    Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                    This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-06-2024, 11:40 AM
