how hot is safe for an nForce2 IGP chipset?
  • gdement
    • Jan 2007
    • 690
    I was running memtest86 on a board with an nForce2 IGP (Geforce4 MX integrated) chipset. The chipset has a passive heatsink.
    After about 10 minutes of memtest, I checked the temperature using a thermocouple at the center base of the heatsink. I got 51C. This is in open air.
    I imagine it will be hotter a year from now, running 3D in a dusty case.
    Any opinions on how hot is safe for these chipsets over the long term? Just curious how close I am to a problem.
    The nuisance of it is that this heatsink won't hold a fan. To install a fan I'd have to downgrade to a tiny 440BX heatsink. The chipset heatsinks on newegg are expensive and don't look appealing.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: how hot is safe for an nForce2 IGP chipset?
    GF2 chipset is notorious for being white hot.
    51C is not too bad, maybe put a fan blowing onto it somehow if you are uncomfortable.
    • bgavin
      • Jan 2007
      • 1355
      Look into buying a Rocket V cooler from Newegg for $9.95 USD.
      It sits in an used PCI slot and uses two 70mm fans to cool a passive video card and adjacent heat sinks.
      I find the Rocket does a great job of cooking bridge sinks, depending upon where you locate the air stream.
      • DynaxSC
        Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
        by DynaxSC
        Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
        For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
        06-10-2023, 11:30 AM
      • harp
        Metod for removing glued heatsink from fragile component
        by harp
        I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
        06-23-2025, 02:01 PM
      • Ven
        Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
        by Ven
        I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
        The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
        I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
        If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
        07-08-2024, 09:32 AM
      • qayyum786
        *Use Full MOST COMMON I.C FOR LAPTOP YOU SHOULD HAVE IN STOCK*
        by qayyum786
        *MOST COMMON I.C FOR LAPTOP*
        *YOU SHOULD HAVE IN STOCK*
        *Charging IC
        8682L OZ8682L OZ8682LN QFN-16 Chipset
        OZ8681LN OZ8681L OZ8681 8681 8681L QFN-16 Chipset
        ISL88731CHRTZ ISL88731C 88731C QFN-28 Chipset
        ISL88731HRZ ISL88731QFN-28 Chipset
        ISL6251AHAZ ISL6251A ISL6251 SOP-24
        ISL95521HRZ ISL95521 95521HRZ QFN-32 Chipset
        AXP288 QFN-76
        AXP288C QFN-76
        CD3301 CD3301RHHR QFN-36 Chipset
        CD3301BRHHR CD3301B QFN-36
        BQ24705
        BQ24707 BQ707
        BQ07A BQ24707A QFN-20
        BQ715 BQ24715 BQ24715RGRR
        05-26-2020, 06:13 AM
      • harp
        can fanless heatsink replace poor original on RX26PG2
        by harp
        I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
        06-25-2025, 10:56 AM
