Who's good with Hexidecimal?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Ok, a BIOS modding that I can't figure out..... I need to convert a bin file from a 1mbit (128k) to a 2mbit (256k) filesize. It's for a retro build that has onboard SCSI, and I want to add some option ROM's (scsi RAID abilities) to the bin, but its too small and I can not add any more.....so increasing the file size (which increases its capacity) and using a 2mbit eprom will fix this.....but the problem is, I've exhausted all my BIOS hacking tricks (unsuccessfully) to do this..... The file is attached, so feel free to take a crack at it!! There could be an e-cookie in it for someone who can figure this out!!!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • 31011
    Re: Who's good with Hexidecimal?
    open a dos-box and
    "copy /b rom.bin+rom.bin rom2.bin"
    or in Linux:
    "cat rom.bin rom.bin > rom2.bin"
    • Curious.George
      • Nov 2011
      • 2305
      • Unknown
      Re: Who's good with Hexadecimal?
      Originally posted by stj
      open a dos-box and
      or in Linux:
      This just appends a second copy of the first ROM image to the end of the first copy and stores it as a new file.
      I would assume there are other "structures" in the ROM image that tell the BIOS where to find stuff, what range of addresses to examine when computing a checksum, where the checksum is stored, etc.?
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        Yes. The extra space I'd guess would just be zero filled, ASSuming that the structure remains intact, and modbin & cbrom simply see it as a 2mbit .bin. The original .bin contains the motherboard parameters, so naturally, they can't be removed or readdressed. I did try taking a 2mbit 4.51 compatible .bin, removing the ROM's in it, and inserting the ROM's for this .bin with cbrom, that didn't work either....
        Team : 49813
        Join in!!
        Team Stats
        • Sparkey55
          • Jan 2010
          • 1523
          http://warp9-systems.proboards.com/
          Get in contact with Mr.Scott He is very smart about BIOS modding and such.
            • 31011
            you make 2 because you dont know if the host expects it to be aligned with the start of the flash, or the end.
            • Dan81
              SNES-powered
              • Oct 2013
              • 1865
              The easiest method I came up with:
              1. Download Uniflash (the one made by Rainbow)
              2. Put it on a bootable DOS media (HDD would be the best given it's a old 586 board)
              3. Put your BIOS file on the same media
              4. Boot to the DOS prompt
              5. While at DOS, hotflash a 2Mb EEPROM in the DIP32 socket
              6. Write this on the prompt: uniflash -e yourbiosfilename.bin
              7. Uniflash should at this point ignore the fact that you are trying to flash a 1Mb file on a 2Mb EEPROM
              8. Once the flash finishes successfully (no red blocks), then start Uniflash again, this time with no switches
              9. Select the first option called "Write backup BIOS image to file" then input the filename you want to save it with.
              10. Connect the drive you just saved the BIOS to the PC you have CBROM on and check the BIOS image integrity and filesize.
              Main rig:
              Gigabyte B75M-D3H
              Core i5-3470 3.60GHz
              16GB DDR3-1600
              Samsung SH-224AB DVD-RW
              Delux MG760 case
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                This got real close. Board post'd just fine off step 6 (hotflashed to 2mbit eprom). Dumped it back off, file size is correct (256k). CBROM sees everything as it should be. attempted to edit with modbin, brick wall....'corrupt header' errors. Any attempt to rewrite (even unmodified), write appears to go (no red blocks), but verification fails, and no POST. Hmmmm....but hey, this is the closest I've gotten so far!! I had to move this off the bench to work on some other stuff, but I'll get back to it. Thanks for the info!!
                Team : 49813
                Join in!!
                Team Stats
